How to couple the OpenFOAM and the other solver.
Old   April 6, 2020, 00:14
Default How to couple the OpenFOAM and the other solver.
Hiroaki Sumikawa
Hiroaki Sumikawa is on a distinguished road
Hi, i'm trying to use lumpedPointsMotion.
This solver can do FSI by coupling the other stress analysis solver.
In the tutorials, there is sampling data which contains the results of stress analysis, and i can understand how to use tutorial case. However, i can't coupled external solver with openfoam. i want to do following.
1) first, OpenFOAM calculate fluid region. <- simpleFoam
2) OpenFOAM calculate the pressure which acting on the object. <- lumpedPointsMotion
3) External solver (ex. calculix) recieve the pressure information, and calculated the displacement.
4) Ecternal solver send the displacement information to OpenFOAM.
5) go back to 1 and repeat.
the problem is that interaction between 2)and3), 4)and 5) doesn't work.
if you know someting about this solution or hints please tell me.
thank you.
Hiroaki Sumikawa is offline   Reply With Quote
Old   April 6, 2020, 01:44
Troy Snyder
tas38 is on a distinguished road
The preCICE project is working to do precisely what you have described. Below is a link to tutorials for linking OpenFOAM and CalculiX
https://github.com/precice/precice/w...M-and-CalculiX
tas38 is offline   Reply With Quote
Old   April 6, 2020, 02:40
Hiroaki Sumikawa
Thank you for your reply. I'll try it.
