potentialFoam - How to set velocity field
dear, all
I am currently investigating a particel flow (Solver: DPMFoam). To speed up the simulation I would like to calculate a potential flow first. Like it is done in the Motorbike Tutorial. In the DPMFOAM simulation the velocity field is called U.air. Is there a way that I "tell" potentialFoam that the velocity field is called U.air. Or can I calculate potentialFoam with U and then map from U to U.air (with mapFields) Here the (obvious) error message from potentialFoam: Code:
potentialFlow: Operating solver in PISO mode Marcel |
