acousticDampingSource
1. does anybody know how selectionMode with cellZone work? with this fvOptions there is always same error message: [0] --> FOAM FATAL ERROR: [0] Cannot find cellZone selectedCells Valid cellZones are 0() 2. or are there another selectionMode, except of "all;"? -> I saw a tutorial used selectionMode all; but I think it does not make any sense, cuz all of cells are damped. https://develop.openfoam.com/Develop...stem/fvOptions 3. what does duration 1000; mean? Code:
acousticDampingSource |
1. you need to create a cellZone first by using topoSet.
2. options are, afaik: all, cellZone, cellSet (at the moment, you need to specify `selectionMode all` if you wanna use `all` mode, as `selectionMode` is a mandatory entry - but may be in the future, it can become an optional entry, don't know). 3. duration = until what time you want function object being executed. e.g. if your simulation endTime=100, and duration=50, the execution of this FO will cease after 50, but your simulation will keep going. |
