April 21, 2020, 13:31 |
What Outlet Boundary Condition Should I Use
Jeff Stout
Rep Power: 6 |
I copied the case from rotatingFanInRoom and modified it for my problem. This is an incompressible PimpleFoam case. Then I changed the case to model a rotating valve in a cylinder.
I have a constant velocity on the inlet, and I want to measure the pressure on the outlet, and back pressure on the inlet. The rotatingFanInRoom specifies U like this: inlet { type fixedValue; value uniform (-0.1 0 0); } outlet { type pressureInletOutletVelocity; value uniform (0 0 0); } The pressureInletOutletVelocity BC I copied from rotatingFanInRoom is not giving me good results. I tried replacing the outlet BC with zeroGradient but the simulator blew up after about 7 hours. But I'm not sure where to place the blame since I changed half a dozen other things at the same time. Is zeroGradient the right boundary condition for this type of problem? |
outlet boundary condition, pimplefoam |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
volumetric flow rate is fluctuating in outlet boundary condition location | oozcan | FLUENT | 1 | November 30, 2016 03:00 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
