April 29, 2020, 13:39 |
sclsVOFFoam dambreak case
Carol Maria
Hi everyone!
I'm new openFOAM user. I'm have a trouble when I use the sclsVOFFoam solver for dambreak case. I'm using openFOAM 2.3.1, as indicate in this tutorial: http://www.tfd.chalmers.se/~hani/kur...ankarMenon.pdf and the changes for dambreak case, according this contribution that I found in github: http://github.com/saatt/01-250SG . But I kept the same geometry of the default openFOAM tutorial. I set up boundary conditions and controldict subdirectories. >> Laminar flow results: The simulation on paraview have shown that the water column starts flow by gravity, collides in the obstacle and after returns to the wall and disappear. >> Turbulence flow results: The simulation on paraview have shown that the water column starts flow by gravity, collides in the obstacle and after decreased and returns, but not desappear. Anyone have already tried run that case sometime? I have been wondering if the clsvof solver maybe would be more appropriate for only diffusive problems.. Any help will be appreaciated |
openfoam, sclsvof dambreak flow |
Reporting a bug in Allrun script on wingMotion case | i.sabahi | OpenFOAM Bugs | 0 | June 10, 2018 09:00 |
Dambreak case can't be simulated by the simple coupled level set and vof (sclsvof) | saatt | OpenFOAM Running, Solving & CFD | 1 | January 21, 2018 17:40 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
[General] Water surface profile in OpenFoam dambreak case | kerim | ParaView | 3 | February 20, 2012 03:52 |
Runing InterFoam for 3 D damBreak case Patch issue | nishant_hull | OpenFOAM Running, Solving & CFD | 5 | February 18, 2009 00:32 |
