June 26, 2019, 18:40 |
Adding a source term to the epsilon equation
Rep Power: 8 |
Hello
In my computational domain I want to add a source term to the equation of the turbulence model using the fvOptions framework. The source term depends on the distance from the inlet and the velocity: Where is distance from the inlet boundary condition and is the local x-velocity. How can I use fvOptions to achieve that? Thank you |
May 3, 2020, 00:55 |
René Thibault
Rep Power: 6 |
Hi!
Did you find a solution? I got the same issue here...trying to add a source term to k-e model? |
[swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 16:18 |
Adding a source term to k and epsilon equation for buoyancy | rajeshkunwar | OpenFOAM Running, Solving & CFD | 2 | April 19, 2019 07:41 |
Adding a Source Term to Pressure equation pEqn in SimpleFoam | oscar_urri | OpenFOAM | 11 | February 22, 2018 17:52 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
