rhoCentralFoam: Long Simulation times on relatively coarse mesh |
May 1, 2020, 12:51 |
Imthiaz Syed
Rep Power: 6 |
Hello everyone,
I am trying to validate OpenFOAM's rhoCentralFoam solver with the NASA Flat Plate boundary layer for a Mach 2.0 flow: https://turbmodels.larc.nasa.gov/ZPG...ateSS_val.html I am using a relatively coarse 137x97 mesh (with mesh refinement at wall with Y+ approx 1) with the SST turbulence model. This simple simulation takes around 5-6 hours to converge running on 40 cores, which is just weird. For comparison, Steady State SU2 runs this setup in around 30mins, so I am sure I am doing something wrong here. I have here the simulation case, and output: https://drive.google.com/file/d/1X6KgMVktMKPv1h3t0HIo_VpZzDJjbcwR/view?fbclid=IwAR0eZjAEZio7FW9gyTKOCox-6VpJh1QisrG6TJkFZHpZLLJVsfFwooH7h_c You can see the results first using paraFoam if you need, and try running it yourself to see how slow the convergence is. I am unsure if this is due to the Boundary Conditions that I have used, or something that I have defined in my fvSchemes or controlDict, so if anyone can comment on that, I would very much appreciate it. I got a recommendation to run this simulation first using local time stepping to get a steady state result, then use the unsteady solver to speed this simulation up. However, using LTS, it takes over 3 hours just to get a decent steady state solution, which is also quite concerning. I am at the end of my wits, and I am fairly new to OpenFOAM, so any and all help or advise is much appreciated. Thanks! P.S. I have seen other threads of users commenting on how slow rhoCentralFoam is, but I have also read research papers that credit rhoCentralFoam as a relatively fast solver, so I am currently at odds with this info. |
May 1, 2020, 16:16 |
Rep Power: 14 |
First issue I see is that 40 processors is way (way) too many for a case this small (~13k cells). To illustrate, I took the hyStrath mach 2 flat plate example (https://github.com/vincentcasseau/hy...arFlatPlateLTS) and reduced it to approximately the same size (~14k cells). It ran on a single processor in about 0.7 hours. (Note that I've just done this to show how long a similar case might take with a similar solver -- the mesh and results will likely be different than what you will get with rhoCentralFoam).
Caelan |
May 1, 2020, 17:52 |
Imthiaz Syed
Rep Power: 6 |
Yes, I agree with you, which is why I am really confused about this. I guess something different between the case you describe and what I am running is yours is a laminar flow while this here is turbulent using the SST model. Any ideas on why this simple case is so expensive to run?
May 1, 2020, 18:00 |
Rep Power: 14 |
Have you run yours in serial? Like I said, mine is run in serial. I've not run rhoCentralFoam much with a turbulence model, so perhaps someone who has could step in.
Caelan |
May 2, 2020, 05:39 |
Thomas Sprich
Rep Power: 11 |
Please test as Caelan has suggested and run your case on a single core (in serial). Generally you should have 50k-100k cells per core, above which you will get no improvement in solve time. The reason is that the inter-processor communication becomes the bottleneck in the solution. See this for a discussion on running in parallel. Lets rule out this issue as a cause for your slow solve time which will put us in a better position to solve your issue. Regards, Thomas |
May 3, 2020, 23:14 |
Imthiaz Syed
Rep Power: 6 |
Hi everyone,
I did some more reading the past day and thought it might have been with some of my boundary conditions. Sure enough, the simulation runs quicker, but it still takes around 5-6 hours to simulate. In regards to @clapointe and @Swift, I reran the simulation on a single core, and as you both suspected, there was little to no change in performance. It is very slightly faster with the extra cores, but performance is definitely not proportional to the 39 extra cores. Here is the updated zip, with a lower resolution mesh. This one is reaaally coarse, but still takes around 1.5hours-2hours to converge: https://drive.google.com/open?id=1sU...MfW15ujUUjDOXi I am still struggling to comprehend why these simulations are taking so long to converge, or do you think this convergence rate is about nominal for cases at these Mach Numbers with low-Re treatment at the wall? Thanks! |
May 4, 2020, 12:55 |
Thomas Sprich
Rep Power: 11 |
I'm not an expert in rhoCentralFoam, so bear this in mind when considering my response. The first thing that I would do is use a regular mesh to avoid the high aspect ration that you have. See the checkMesh log below: Code:
Checking geometry... Overall domain bounding box (-0.33333 0 -0.5) (2 1 0.5) Mesh has 2 geometric (non-empty/wedge) directions (1 1 0) Mesh has 2 solution (non-empty) directions (1 1 0) All edges aligned with or perpendicular to non-empty directions. Boundary openness (-4.8980485e-18 9.796097e-18 -5.7062265e-16) OK. ***High aspect ratio cells found, Max aspect ratio: 35828.266, number of cells 189 <<Writing 189 cells with high aspect ratio to set highAspectRatioCells Minimum face area = 5.5396231e-08. Maximum face area = 0.37220328. Face area magnitudes OK. Min volume = 5.5396231e-08. Max volume = 0.069742525. Total volume = 2.33333. Cell volumes OK. Mesh non-orthogonality Max: 0 average: 0 Non-orthogonality check OK. Face pyramids OK. Max skewness = 8.3811437e-15 OK. Coupled point location match (average 0) OK. Failed 1 mesh checks. The next thing to check are your boundary conditions for k. You have specified the inlet and outlet values. I would make the outlet zeroGradient (which you seem to have had before) and the obstacle I would initialise with the $internalField. The next comments are loooong shots but they stood out for me as things I would check. I have only had nuTilda as zeroGradient in my simulations - so check if you are sure that is correct. Likewise for nut, I have only used wallFunctions, never calculated. I hope you find something useful in that. Thomas |
Display Modes | |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 12:14 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
Airfoil simulation solution interfered by mesh | Dvergr | OpenFOAM Running, Solving & CFD | 1 | September 28, 2014 03:05 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 07:21 |
