MotorBike Tutorial failing to show proper results
Dear Foamers,
I have successfully built OFV1912 on an arm device and I was able to run elbow, pitzDaily, airFOIL2D, simpleCar and rotorDisk. Its only when running the Allmake for MotorBike that I run into a problem. The allmake script runs to fast and when I use paraFoam to view results, paraview only shows solid body, no values for P, U, Nu, etc. I checked the logs and it just shows a warning saying mpirun as root is not recommend. I assume its due to mpi on my device (which is an android phone running ubuntu 19.10 via a container). Is there away to run this tutorial without mpi? The case runs fine on my x86 device so I know its a mpi issue. |
>> saying mpirun as root is not recommend Don't run it in parallel? Or do not try to run anything which requires root access? |
How to run in serial then?
Also when running any parallel cause I get this error warning: Code:
[localhost:31131] opal_ifinit: ioctl(SIOCGIFHWADDR) failed with errno=13 |
- Have you installed OpenFOAM in root or your user area? |
Installed in opt folder. However i can verify its mpi issue, mpi didn't setup properly on my proot. |
- I am still not sure, since it seems that you have made the installation to the root area. Hope you find solution. |
