Alphawater go down abruptly to a small number
Hi Foamers,
I am about to use interFoam for mudflow simulations using Herschel-Bulkley rheology. prior to my main job, I am simulating the conventional 3d dambreak by only changing the rheology of the fluid and assuming laminar flow. When I do simulate by varying the parameters tau0 and k, for certain combination of these parameters, I am facing this problem: - After certain time step the fluid with alphawater=1.0 is disappearing. At some point of time alpha always go down abruptly to a very small number (order of 1.0e-5 even lower). - I can't understand the physical implication. Does this have anything with my mesh size? |
- Have you correctly inspect the values? Have you inspected them visually? - Why do you think the value would be problematic? |
Thank you HPE,
For my case I used a 6 degree inclined flume of length 4m, width 1m and height 1m with a Herschel bulkley fluid of tau0 =0.01, k =9.6e-3, n=0.34 and rho =1350. The dam size was 1mx1mx0.5m. The grid size was 50mm. After running interFoam and visualizing taking the free surface at alphawater=0.5( Contour at alphawater =0.5), it went as normal as the dambreak tutorial for newtonian fluids until the simulation time is 0.4 seconds. Afterwards the fluid disappeared from the flume. I tried to to inspect the results and the alphawater range was between 0.0 to 1.0 until t =0.4 seconds. After that the range went to 0.0 to 1.0e-16 just after t =0.41. I did not know why? ************************************************ What I was expecting was the flow would continue until the applied shear stress due to the weight of the fluid is less than tau0 (yield stress). |
