Ability to run an openFOAM case at specific time
Hey all,
I was wondering if someone knows a way to run a CFD case at a later time in the future. So, for example, you can say: run the command ./Allrun at this time. I have tried this with the at command that is available in Linux and this worked for everything except the allrun command. ./Allclean, for example, works as intended. When you give the command: at now + 1 minutes at> ./Allclean at><EOT> It will clean the case one minute later. However when I try this with the following Allrun command it will run at the specific time, but the individual processes will not run and all return errors that the libaries can not be found. Code:
[URE14@urepower8 512_F40_R30]$ at now + 1 minutes Running surfaceFeatureExtract on ../512_F40_R30 While the log.surfaceFeatureExtract returns: surfaceFeatureExtract: error while loading shared libraries: libsurfaceFeatureExtract.so: cannot open shared object file: No such file or directory It seems the command can not find the libraries, but I assumed that the command should run in same shell as specified in the script right? This is the allrun script: Code:
#!/bin/sh Thank you, Max |
