inobsobot |
May 16, 2020 12:55 |
interFOAM : random SigSegv
1 Attachment(s)
Dear foamers,
I am trying to run a case with interfoam, derived from the waterChannel tutorial. The geometry is different, as the mesh (snappyhexmesh, checkMesh OK) and initial conditions (see image). Boundary conditions are the same as the tutorial, so are controlDict (except the added function #includeFunc residuals), fvScheme and fvSolution. I run openfoam 7 on ubuntu 20.04 64 bit.
The calculation starts and run smoothly then suddenly crashes without blowing up. What I mean is that everything seems fine (residuals, inlet and outlet fluxes, max velocity) when the crash happens. Here are the last three iterations and the error message :
smoothSolver: Solving for alpha.water, Initial residual = 0.00119021, Final residual = 7.19883e-09, No Iterations 3
Phase-1 volume fraction = 0.242722 Min(alpha.water) = -4.16565e-09 Max(alpha.water) = 1.00001
MULES: Correcting alpha.water
Phase-1 volume fraction = 0.242722 Min(alpha.water) = -0.00076294 Max(alpha.water) = 1.00039
GAMG: Solving for p_rgh, Initial residual = 0.0168586, Final residual = 0.000120603, No Iterations 2
time step continuity errors : sum local = 0.000809142, global = 1.39209e-06, cumulative = -9.96522e-06
GAMG: Solving for p_rgh, Initial residual = 0.000345433, Final residual = 3.85913e-09, No Iterations 22
time step continuity errors : sum local = 2.57429e-08, global = -3.81059e-10, cumulative = -9.9656e-06
smoothSolver: Solving for omega, Initial residual = 0.00707939, Final residual = 0.000143963, No Iterations 1
smoothSolver: Solving for k, Initial residual = 0.0212891, Final residual = 0.000628071, No Iterations 1
ExecutionTime = 230.59 s ClockTime = 231 s
surfaceFieldValue inletFlux write:
sum(inlet) of rhoPhi = -100
surfaceFieldValue outletFlux write:
sum(outlet) of rhoPhi = 216.906
surfaceFieldValue atmFlux write:
sum(atm) of rhoPhi = -0.439954
Courant Number mean: 0.173153 max: 6.19933
Interface Courant Number mean: 0.011299 max: 2.24993
deltaT = 0.00732468
Time = 0.495321
smoothSolver: Solving for alpha.water, Initial residual = 0.00116221, Final residual = 6.20313e-09, No Iterations 3
Phase-1 volume fraction = 0.242708 Min(alpha.water) = -4.09478e-09 Max(alpha.water) = 1.00001
Phase-1 volume fraction = 0.242708 Min(alpha.water) = -0.000681019 Max(alpha.water) = 1.00036
GAMG: Solving for p_rgh, Initial residual = 0.0164629, Final residual = 0.000117117, No Iterations 2
time step continuity errors : sum local = 0.000745443, global = 3.72879e-07, cumulative = -9.59272e-06
GAMG: Solving for p_rgh, Initial residual = 0.000343821, Final residual = 4.91956e-09, No Iterations 22
time step continuity errors : sum local = 3.11446e-08, global = -3.32987e-09, cumulative = -9.59605e-06
smoothSolver: Solving for omega, Initial residual = 0.0067972, Final residual = 0.000129168, No Iterations 1
smoothSolver: Solving for k, Initial residual = 0.0202467, Final residual = 0.000561078, No Iterations 1
ExecutionTime = 234.09 s ClockTime = 234 s
sum(outlet) of rhoPhi = 216.794
sum(atm) of rhoPhi = -0.439018
Courant Number mean: 0.168407 max: 6.11036
Interface Courant Number mean: 0.0110264 max: 2.17041
deltaT = 0.0071845
Time = 0.502505
smoothSolver: Solving for alpha.water, Initial residual = 0.00115311, Final residual = 5.75125e-09, No Iterations 3
Phase-1 volume fraction = 0.242695 Min(alpha.water) = -4.85068e-09 Max(alpha.water) = 1.00001
Phase-1 volume fraction = 0.242695 Min(alpha.water) = -0.000757292 Max(alpha.water) = 1.00035
GAMG: Solving for p_rgh, Initial residual = 0.0161444, Final residual = 0.000116495, No Iterations 2
time step continuity errors : sum local = 0.000719951, global = 1.22603e-07, cumulative = -9.47345e-06
GAMG: Solving for p_rgh, Initial residual = 0.000345299, Final residual = 4.9922e-09, No Iterations 25
time step continuity errors : sum local = 3.06927e-08, global = -5.35778e-09, cumulative = -9.47881e-06
smoothSolver: Solving for omega, Initial residual = 0.00660857, Final residual = 0.000119694, No Iterations 1
smoothSolver: Solving for k, Initial residual = 0.0195878, Final residual = 0.000516912, No Iterations 1
ExecutionTime = 237.7 s ClockTime = 238 s
sum(outlet) of rhoPhi = 216.687
sum(atm) of rhoPhi = -0.438183
Courant Number mean: 0.166024 max: 6.04775
Interface Courant Number mean: 0.0109053 max: 2.14029
deltaT = 0.00712757
Time = 0.509633
smoothSolver: Solving for alpha.water, Initial residual = 0.00115602, Final residual = 5.62226e-09, No Iterations 3
Phase-1 volume fraction = 0.242682 Min(alpha.water) = -4.83732e-09 Max(alpha.water) = 1.00001
Phase-1 volume fraction = 0.242682 Min(alpha.water) = -0.000996971 Max(alpha.water) = 1.00032
GAMG: Solving for p_rgh, Initial residual = 0.0161208, Final residual = 0.000117379, No Iterations 2
time step continuity errors : sum local = 0.000718305, global = -1.23836e-07, cumulative = -9.60265e-06
#0 Foam::error::printStack(Foam::Ostream&) at ??:?
#1 Foam::sigSegv::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::tmp<Foam::GeometricField<Foam::innerProduct<Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh>::value_type, Foam::Vector<double> >::type, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::surfaceInterpolationScheme<Foam::Vector<double> >::dotInterpolate<Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> >(Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > const&) at ??:?
#4 Foam::fv::correctedSnGrad<double>::fullGradCorrection(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const at ??:?
#5 Foam::fv::correctedSnGrad<double>::correction(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const at ??:?
#6 Foam::fv::snGradScheme<double>::snGrad(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const at ??:?
#7 Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::fvc::snGrad<double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/interFoam"
#8 Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::fvc::snGrad<double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/interFoam"
#9 Foam::interfaceProperties::surfaceTensionForce() const at ??:?
#10 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/interFoam"
#11 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#12 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/interFoam"
Segmentation fault (core dumped)
The strangest thing to me is that the exact same simulation will crash at different timestep when run twice in a row. I must also mention the simulation is a single process. Running in parallel only seem to make the simulation crash earlier (first 3 timesteps).
Help would be much appreciated. I can provide details of the case but as I mentioned, it is mostly the water channel tutorial.
