Marangoni bc
Like Tree7Likes
Old   November 6, 2007, 10:59
Default Hi all, I am trying to spec
Zaki Saldi
zakifoam is on a distinguished road
Hi all,
I am trying to specify Marangoni boundary condition on the top boundary of a cavity. At first, I am trying to 'enforce' this b.c in the main code I am using (boussinesqBouyantFoam). Later, I will try to learn how to incorporate it in a new b.c library (i.e the elegant way).
The b.c is:
du/dy = (dSigma/dT)*(dT/dx)/mu
dw/dy = (dSigma/dT)*(dT/dz)/mu
where (dSigma/dT) is temperature gradient of surface tension, assumed to be constant.
The implementation is as follows:
volVectorField gradT = fvc::grad(T);
volScalarField dTdx = gradT.component(0);
volScalarField dTdy = gradT.component(1);
volScalarField dTdz = gradT.component(2);
label patchI1 = mesh.boundaryMesh().findPatchID("top");
volScalarField u = U.component(0);
volScalarField v = U.component(1);
volScalarField w = U.component(2);
fixedGradientFvPatchScalarField& bufferu = refCast<fixedgradientfvpatchscalarfield>(u.boundar yField()[patchI1]);
fixedGradientFvPatchScalarField& bufferv = refCast<fixedgradientfvpatchscalarfield>(v.boundar yField()[patchI1]);
fixedGradientFvPatchScalarField& bufferw = refCast<fixedgradientfvpatchscalarfield>(w.boundar yField()[patchI1]);
scalarField graduyTop = bufferu.snGrad();
scalarField gradwyTop = bufferw.snGrad();
fvPatchScalarField& dTdxTop = dTdx.boundaryField()[patchI1];
fvPatchScalarField& dTdzTop = dTdz.boundaryField()[patchI1];
forAll (graduyTop, faceI1)
graduyTop[faceI1] = dsigmadT.value()*dTdxTop[faceI1]/mu.value();
forAll (gradwyTop, faceI1)
gradwyTop[faceI1] = dsigmadT.value()*dTdzTop[faceI1]/mu.value();
There was no error message upon compiling. For the simulation, I used fixedGradient b.c for velocity at top surface, i.e:
in 0/U:
top
type fixedGradient;
gradient uniform (0 0 0);
When running the simulation, I got this error message:
--> FOAM FATAL ERROR : Attempt to cast type calculated to type fixedGradient
From function refCast<to>(From&)
in file /home/zaki/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/typeInfo.H at line 103.
FOAM aborting
Foam::error::printStack(Foam:stream&)
Foam::error::abort()
marangoniFoam [0x4142cb]
__libc_start_main
__gxx_personality_v0
Could anyone explain and help me with this problem?
Thanks,
zaki
zakifoam is offline   Reply With Quote
Old   November 8, 2007, 04:14
Default Hi Zaid, I have not really
Thomas Jung
tehache is on a distinguished road
Hi Zaid,
I have not really lookked at your error - but I have implemented (and tested) a Marangoni boundary condition.
Have a look at it, maybe it serves you.
regards,
Thomas
marangoniFvPatchVectorField.H
marangoniFvPatchVectorField.C
jie.chen likes this.
tehache is offline   Reply With Quote
Old   January 22, 2008, 12:46
Default Hi Thomas, Thanks for the b
Zaki Saldi
Hi Thomas,
Thanks for the b.c code you provided. Sorry for not replying for long time since I've been busy with other things. Now I want to concentrate back on marangoni b.c.
I tried to compile the marangoni b.c but I got the following error:
/home/zaki/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude/fvPatchField.H:132 : instantiated from 'Foam::fvPatchField<type>::adddictionaryConstructo rToTable<fvpatchfieldtype>:: adddictionaryConstructorToTable(const Foam::word&) [with fvPatchFieldType = Foam::marangoniFvPatchVectorField, Type = Foam::Vector<double>]'
marangoniFvPatchVectorField.C:228: instantiated from here
/home/zaki/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude/fvPatchField.H:132 : error: cannot allocate an object of abstract type 'Foam::marangoniFvPatchVectorField'
marangoniFvPatchVectorField.H:51: note: since type 'Foam::marangoniFvPatchVectorField' has pure virtual functions
make: *** [Make/linux64GccDPOpt/marangoniFvPatchVectorField.o] Error 1
Could you explain what might happen?
Thanks
zaki
Old   February 25, 2008, 06:35
Default Hi Zaki, I think that versi
Thomas Jung
Hi Zaki,
I think that version I posted worked for OpenFoam-1.3.
I have a version adapted to version 1.4.1, which you are apparently using, but I have to say I right now do not remember if I tested that. I have set up an installation for 1.4.1 some time ago, compiled it, but am actually still using the 1.4 version. So, here, at your own risk, the 1.4.1 version.
Please note, that in 1.4.1 also the directory structure in fvPatchFields changed, if I remember correctly.
Good luck...
Thomas
Old   February 25, 2008, 10:51
Default Hi Thomas, Thanks a lot! ht
Zaki Saldi
Hi Thomas,
Thanks a lot! The compilation was successfully done. Now I'm trying to run a test case.
zaki
Old   January 19, 2009, 16:10
Default Hi Thomas and Zaki, Is it
Michael Jaworski
mike_jaworski is on a distinguished road
Hi Thomas and Zaki,
Is it possible for one of you to upload an example solver and case file using this boundary file?
Thanks,
Mike J.
mike_jaworski is offline   Reply With Quote
Old   January 21, 2009, 18:16
Default Hello FOAMers, I am havi
Michael Jaworski
Hello FOAMers,
I am having difficulty getting the marangoni BC to operate correctly and I am hoping for a hint about what I am doing wrong.
First, I am integrating this BC into a solver which uses the conjugateHeatFoam as a template and so have two mesh regions coupled by the energy equation (the fluid portion is replaced with the mhdFoam solver).
Second, I have compiled the BC with the help of the instructions here. It compiles and apparently links correctly.
Third, I have a case file and the <case>/0/U file includes the BC as follows:
boundaryField
movingWall
type marangoni;
marangonicoeff 0.147e-3;
Now, when I run the case like this, I get a message that reads:
marangoniFvPatchVectorField::snGrad(): object gradT not found!
and no flow. So, looking at the source code which Thomas above supplied, I find the following line:
if(!db().foundObject<vectorfield>("gradT")) {
Info << " marangoniFvPatchVectorField::snGrad(): object gradT not found!" << endl;
I think to myself: ah, it expects me to create a volVectorField called gradT somewhere in the solver to calculate this material.
I dutifully add the line:
underneath the reading in of the temperature field in the solver code.
The solver compiles without a hitch.
However, when I run the solver, I get the following error message:
Reading field p
Reading field T
Creating field grad(T)
request for volScalarField T from objectRegistry solid failed
available objects of type volScalarField are
0
From function objectRegistry::lookupObject<type>(const word&) const
in file /home/mjaworsk/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/objectRegistryTe mplates.C at line 142.
FOAM aborting
Aborted
Ack!
Can anyone help me with this error?
Thank you,
Mike J.
Old   January 22, 2009, 07:20
Default Hi Mike, The BC is looking
Kati Laakkonen
kati is on a distinguished road
Hi Mike,
The BC is looking for gradT in database, so you should create it like you do for fields that are written and read from time dumps, i.e. something with IOobject.
Regards,
Kati
kati is offline   Reply With Quote
Old   January 23, 2009, 02:48
Default Hi Kati, This did, indeed
Michael Jaworski
Hi Kati,
This did, indeed, solve my problem. Thank you.
Regards,
Mike J.
Old   April 20, 2009, 10:56
Atsuko Ishida
Hanna is on a distinguished road
I'm new to OpenFOAM and C++ language.
I have a diffucult using the "MarangoniFvPatchVectorField".
Now, I am bringing this BC in solver (icoheatMaFOAM).
However, I couldn't compile the solver and getting following error message.
…/lnInclude/marangoniFvPatchVectorField.H:107: error: cannot allocate an object of abstract type ‘Foam::marangoniFvPatchVectorField’
…/lnInclude/marangoniFvPatchVectorField.H:58: note: because the following virtual functions are pure within ‘Foam::marangoniFvPatchVectorField’:
…/lnInclude/transformFvPatchField.H:109: note: Foam::tmp<Foam::fvPatchField<Type> > Foam::transformFvPatchField<Type>::clone(const Foam:imensionedField<Type, Foam::volMesh>&) const [with Type = Foam::Vector<double>]
…/lnInclude/marangoniFvPatchVectorField.H: In member function ‘virtual Foam::tmp<Foam::fvPatchField<Foam::Vector<double> > > Foam::marangoniFvPatchVectorField::clone(const Foam::vectorField&) const’:
…/lnInclude/marangoniFvPatchVectorField.H:123: error: cannot allocate an object of abstract type ‘Foam::marangoniFvPatchVectorField’
…/lnInclude/marangoniFvPatchVectorField.H:58: note: since type ‘Foam::marangoniFvPatchVectorField’ has pure virtual functions
Could anyone help me with this error.
Thank you.
Hanna
Hanna is offline   Reply With Quote
Old   March 31, 2010, 13:15
isabel
isabel is on a distinguished road
Hello everybody,
I have succesfully compiled the boundary condition which Thomas tehache supplied.
In the solver, I have created the gradT as an IOobject:
IOobject
"gradT",
runTime.timeName(),
mesh,
IOobject::READ_IF_PRESENT,
IOobject::AUTO_WRITE
fvc::grad(T)
In the boundary conditions I wrote this:
boundaryField
type marangoni;
marangonicoeff 0.05;
The code compiles and runs ok. But when I execute the command foamDataToFluent (I am using Fluent as a posprocessor) I have the following warning:
Time = 0
Converting field pd
Converting field T
Converting field gradT
gradT is defined but the solver do not find it. And in the postprocessor I can see that gradT is not zero and is calculated oK.
Other problem is that the solver is not aplying this condition, i.e. although I set the marangonicoeff = 1000000, I have no difference between marangonicoeff = 0.05 or marangonicoeff = 0
Does anybody know which is the problem. May be the boundary conditions of temperature or velocity?
isabel is offline   Reply With Quote
Old   April 1, 2010, 08:25
Thomas Jung
I have to leave now (urgent holidays...) ... but promise to post next week the version I am currently using with OpenFoam 1.6.x, where the value field is beeing written, and which needed changes to work with 1.6.x.
Thomas
Old   April 9, 2010, 03:28
Thomas Jung
I updated the boundary condition a little (its now writing also its value, was missing before..), and its working for me now with 1.6.x.
As the testcase was too large to upload here, please find it (and the B.C.) at the links given below.
Under the link named MarangoniTest I add a small testcase. Gravity is set to 0, Marangoni-Number is small in order to obtain a stationary and axisymmetric solution (although calculation is 3D), which I have compared to results from our own 2D-Code Crysmas, and with Fluent, results are (within some percent, did not check grid dependence..) the same.
Therefore, I personally trust it, but dont give any guarantee
I have run the testcase using a slightly modified buoyantBoussinesqSimpleFoam:
add this to createFields to store temperature gradients:
Info<< "Generating/reading field gradT\n" << endl;
IOobject
"gradT",
runTime.timeName(),
mesh,
mesh,
dimensionSet(0,-1,0,1,0,0,0)
gradT=fvc::grad(T);
and add this in the solver code:
turbulence->correct();
-> gradT=fvc::grad(T);
runTime.write();
specify the B.C. in U as follows:
outerwall
type marangoni;
marangonicoeff -9.9e-06;
the marangonicoeff to specifiy is the usual marangonicoefficient (d sigma/dT) divided by DYNAMIC viscosity!
http://servww6.ww.uni-erlangen.de/~jung/marangoniFvPatchVectorField-1.6.x.tar.gz
http://servww6.ww.uni-erlangen.de/~jung/MarangoniTest.tar.gz
Thomas
fuguang and YeWang like this.
Old   April 19, 2010, 03:19
isabel
Thank you very much, tehache. Now my problem works Ok.
Old   February 15, 2012, 05:15
Default marangoni stress
  #15
U.Magarajan
magarajan84 is on a distinguished road
hey everyone,
i am trying to simulate selective laser sintering process with marangoni stress function wrt time as a boundary condition can u suggest me where i can apply this condition. i am using fluent as my solver and if udf is required can somebody help me with that..
thank you.
magarajan84 is offline   Reply With Quote
Old   June 13, 2013, 06:31
Default returning gradient at the boundary
  #16
Srivathsan N
Sherlock_1812 is on a distinguished road
Hi everyone,
I have gone through the marangoniFvPatchVectorField.C file and I have difficulty in understanding parts of the code as I'm not very good at C++ and am new to OpenFOAM
what do the following lines of the code mean?
tmp<vectorField > marangoniFvPatchVectorField::snGrad() const
    //Info << "entering  marangoniFvPatchVectorField::snGrad()" << endl;
    vectorField nHat = this->patch().nf();
    vectorField pif = this->patchInternalField();
    vectorField result;
    if(!db().foundObject<vectorField>("gradT")) {
     Foam::error theError(" marangoniFvPatchVectorField::evaluate(): object gradT not found!");
    return transform(I - sqr(nHat),pif);
    else {
     fvPatchField<vector> gradT =this->patch().lookupPatchField<volVectorField, vector>("gradT");
     vectorField  gradT_internal = gradT.patchInternalField();
     vectorField gradTplane= transform(I - sqr(nHat),gradT_internal);
     vectorField pifplane= transform(I - sqr(nHat),pif);
    result=pifplane+marangonicoeff_*gradTplane/this->patch().deltaCoeffs();
    return (result-pif)*this->patch().deltaCoeffs();
    //Info << "leaving  marangoniFvPatchVectorField::snGrad()" << endl;
    return result;
What does transform do? Does it help us in returning a gradient along the boundary?
Thanks in advance.
Srivaths
Sherlock_1812 is offline   Reply With Quote
Old   June 14, 2013, 06:40
Thomas Jung
Hi sherlock (and others),
As I am getting a lot of private messages regarding the Marangoni B.C.:
I posted this thing 4 years ago just as an example of how I tried to solve the problem, not as something I would consider a good programming example.
It worked for me, and some others, in OpenFoam 1.6, since then, I have not touched it, and actually dont really remember what I did and why.
Perhaps I should not have posted it.
As far as I remember, the transform you are asking for gives the projection of the patch internal vector field onto the patch plane, I think you can figure that out looking at the implementation of the base class, transformFvPatchVectorField.
God luck!
Old   June 15, 2013, 00:37
Default Many thanks
  #18
Srivathsan N
Hi Thomas,
Thank you. I shall have a look at the base class to try and understand this better.
Regards,
Srivaths
Old   August 30, 2013, 07:04
Srivathsan N
Hello all,
I have a 2 questions.
Firstly, I have a doubt in the volVectorField definition of gradT. Why is it READ_IF_PRESENT? I'm not able to view the test case attached and so i'm not able to have a look into the 0/gradT file.
Second, if the internal and boundary fields are at constant temperature initially, won't gradT have the same value at all points?
Kindly excuse me if the questions are too naive. I have just started with OpenFOAM.
Regards,
Srivaths
Old   May 18, 2017, 15:37
Tarang
gtarang is on a distinguished road
IOobject
"gradT",
runTime.timeName(),
mesh,
mesh,
gradT=fvc::grad(T);
runTime.write();
outerwall
type marangoni;
Thomas
Hello Thomas,
I am implementing the same boundary condition. However I want to ask, do we really need to update the solver application? There must be another way of adding this IOobject externally I mean through codeStream or function object. Pl. suggest.
Tarang
gtarang is offline   Reply With Quote
Marangoni stress, help!! dong FLUENT 2 February 23, 2024 12:30
Marangoni flow Tao CFX 0 September 4, 2007 17:14
Marangoni Convection Rucy FLUENT 0 July 6, 2005 05:17
Marangoni Stress At the Wall Peter Nagy FLUENT 4 January 26, 2004 15:06
Marangoni VS Rayleigh-Bernard Peter Nagy FLUENT 2 January 12, 2004 09:53
