mba olufemi
Rep Power: 8 ![]() |
Dear all,
I think I finally understand all the parameters needed for a successful definition of Lagrangian injector and the corresponding kinematicCloudProperties and run my closed geometries simulation. If there is interest I would post my findings. Now I need an advice on the solver. What solver would you advice for simulating a cloud of passively dragged scarce particles in a flow impinging on an obstacle? My particles don’t evaporate or burn; the tunnel they fly in is isothermal and the flow is much below sonic speeds. How to define the interaction properties with the obstacle in a way that that some particles would bounce, some stick and some slip? Is there an example I could study? Thanks a lot Mba |
Rep Power: 16 ![]() |
I would suggest to build your own solver. Your case description seems as pimpleFoam would be a good base. Include the kinematicCloud-functionality there.
The handling of patch collisions is done by patch interaction models. You can find them in "src/lagrangian/intermediate/submodels/Kinematic/PatchInteractionModel/". Having a look at "StandardWallInteraction.C" gives you an example how to define what is done with particles when they hit a patch. Here it is predefined by a switch in a dictionary. Instead, you could for example define a critical normal velocity, below which particles stick, and above which particles bounce. |
Display Modes | |
how to determine the number of particles injected. | welch | FLUENT | 2 | January 18, 2024 04:08 |
dsmcFoam - micro-hole limiting the number of dsmc particles | Araist | OpenFOAM Running, Solving & CFD | 0 | June 25, 2015 06:50 |
Add lagrangian particles to OpenFoam solver | luchen2408 | OpenFOAM | 0 | June 2, 2015 03:10 |
trying to simulate two-phase jet flow with particles in surface injection | ajkratos | FLUENT | 5 | March 3, 2015 21:33 |
particles model | ati_ros61 | FLOW-3D | 3 | December 6, 2009 16:03 |
