June 13, 2020, 09:22 |
twoPhaseEulerFoam cell size
Jagan Mohan
Rep Power: 6 |
Hello Team, I'm looking to compare twoPhaseEulerFoam (2PEF) and CFDEM setup via simulating minimum fluidization velocity. The particle diameter is 1.2 mm.
1. Are there any recommendations / suggestions for cell sizes? 2. Can we have a cell size less than diameter of particle size? Thank you, Jagan Mohan. |
June 16, 2020, 02:49 |
Rep Power: 8 |
1. well, normally you should choose the cell size, so your result should not change with further refinement. mesh or grid independant so to say.
2. i ran multiphaseEulerFoam and had crashes when my cell size was 80% of my drop diameter or so. i don't know if there is any restriction with regards to velocity, so i don't know if it is problematic if your fluid passes multiple cells within one timestep. it would be nice if you could share your experience afterwards. regards |
cell size ratio, twophaseulerfoam |
[mesh manipulation] How to write cellSet for different regions in constant/polyMesh/sets | Struggle_Achieve | OpenFOAM Meshing & Mesh Conversion | 3 | June 17, 2019 09:29 |
FvMatrix coefficients | shrina | OpenFOAM Running, Solving & CFD | 10 | October 3, 2013 14:38 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 21:58 |
cell size | Baskar | Siemens | 4 | January 18, 2006 13:34 |
