I can not get SimpleFoam Simulation to Converge no Matter what I try
Old   June 15, 2020, 04:34
Default I can not get SimpleFoam Simulation to Converge no Matter what I try
NotApplicable
skodali is on a distinguished road
I've been going at this for weeks now, and it's just frustrating at this point, I've remeshed it 3 times, and tried every conceivable combination of simulation parameters, and the forces just continue to shoot off to infinity with no rhyme or reason.
Anyway, if someone can take a look and possibly point out something it could be, I would really appreciate it.
Here is the geometry, I'm using a cylinder "wind tunnel" right now, but I originally was using a square cross-section, remeshed that. I optimize it in gmsh. See this post for how I was originally able to convert from gmsh to openFoam: Gmsh trouble converting to openFOAM?
Geometry: https://imgur.com/a/l1Sm27U
When I try to run it using just simpleFoam, I don't see any residuals shooting off to inifity, it's just that the force coeffs and general timestep continuity starts to shoot off as well: https://i.imgur.com/QpsWXmR.png
Similar thing happens, but happens sooner when I run potentialFoam first: https://i.imgur.com/FSnCf5y.png
Here are all the initial condition files: https://imgur.com/a/u93VaAU
Relavent system files: https://imgur.com/a/gcKRr2k
boundary mesh file: https://i.imgur.com/G9X9g7j.png
Any help would be really appreciated because at this point, I'm about ready to give up on openFoam.
skodali is offline   Reply With Quote
Old   June 16, 2020, 13:46
Klaus
klausb will become famous soon enough
what do you try to simulate?
What's the Reynolds number?
Did you update the turbulence properties?
Do you have a good boundary layer mesh with appropriate y+ ?
Can you show the residual plot using pyFoam?
I assume you tried to modify the simpleFoam motorBike case?
Klaus
klausb is offline   Reply With Quote
Flashback in simulation of propane-air premixed combustion using CONVERGE DongMei CONVERGE 5 January 23, 2023 07:37
Issue when viewing engine simulation from Converge MMatt EnSight 0 December 18, 2019 04:54
Steady microchannel simulation with simpleFoam NiFl OpenFOAM Running, Solving & CFD 0 April 29, 2015 05:32
converge condition for simpleFoam EmadTandis OpenFOAM Running, Solving & CFD 8 December 17, 2011 11:23
discontinous pressure at the corners of a nozzle simulation (simpleFoam) svchb OpenFOAM 3 October 15, 2011 02:20
