pimpleFOAM setup for airfoil stall analysis
Hi all!
I am trying to simulate the flow over a NACA0012 airfoil at stall and post stall, in 2D, using the k-omegaSST model. I understand that the flow separation is inherently a 3D phenomenon but I would still like to know if this approach can work for achieving initial estimates of the cl and cd at high angles of attack. I have only used simpleFoam earlier so I am very new to pimpleFoam. I used the fvSchemes and fvSolution that I found in a previous thread on a similar topic, but that didn't seem to work for me. I tried the fvSchemes and fvSolution from the wingMotion tutorial too, but the calculations stop after a single iteration. My yPlus is 1, and I'm using an O-grid generated from Pointwise. If someone could help me find out what it is that I can do to run this simulation successfully, I would be really grateful. Thanks in advance! Here's my setup: fvSolution Code:
FoamFile Code:
FoamFile Code:
FoamFile Code:
FoamFile Code:
FoamFile Thanks in advance! |
/opt/OpenFOAM/OpenFOAM-v1906/tutorials/compressible/rhoSimpleFoam/aerofoilNACA0012
What you have suggested is to use rhoSimpleFoam.. I will try it out, thanks. However, I am also keen on understanding how to make this case work with pimpleFoam or pisoFoam. Have you tried such a simulation before? I'd love to know. Thanks |
pimpleFoam and pisoFoam are incompressible solvers. They are doomed to fail for sufficiently high Mach number.
Lowering Mach in tutorial case to run pimpleFoam, see how it fares, then return to your case with new eyes?
Hello all,
I want to apologize beforehand due to my offtopic question. I'm just want to ask Ashmita how did you get the pointwise software? I just checked in their website but I was not able to get a license because I'm an Student and they only provide the software to proffesionals(correct me if I am wrong). Thanks in advance for your answer. |
