September 18, 2020, 02:18
turbulent velocity inlet and negative drag coefficients
Hui Zhang
Hello FOAMers,
Recently I have encountered a problem, that is, when I use turbulent velocity inlet to simulate flow past cylinder, I got very weird flow and even negative drag coefficient. When I used laminar velocity inlet, I can get drag coefficient around 1.2, but when I used turbulentInlet boundary condition, I got big problem.
Can anyone help me on this problem, or any comments or suggestions about turbulent velocity inlet setup? Thank you, very much!!
drag coefficients are following, those are part of coefficients and I have run case to 60+ seconds, the results are same.
Force coefficients
# liftDir : (0.000000e+00 0.000000e+00 1.000000e+00)
# dragDir : (1.000000e+00 0.000000e+00 0.000000e+00)
# pitchAxis : (0.000000e+00 0.000000e+00 1.000000e+00)
# magUInf : 1.000000e+00
# lRef : 1.000000e+00
# Aref : 1.000000e+00
# CofR : (0.000000e+00 0.000000e+00 0.000000e+00)
# Time Cm Cd Cl Cl(f) Cl(r)
0.05 -3.637109e-04 -9.393916e+00 -1.913834e-16 -3.637109e-04 3.637109e-04
0.1 -1.069031e-03 2.375448e+01 3.022741e-17 -1.069031e-03 1.069031e-03
0.15 -8.246212e-04 2.057010e+01 4.173255e-17 -8.246212e-04 8.246212e-04
0.2 3.506248e-04 1.181656e+01 -2.843983e-17 3.506248e-04 -3.506248e-04
0.25 -1.027511e-03 5.672581e+01 2.885990e-16 -1.027511e-03 1.027511e-03
0.3 -7.074825e-04 -2.189804e+01 -2.490386e-16 -7.074825e-04 7.074825e-04
0.35 1.543098e-04 -5.380912e+00 -8.722727e-17 1.543098e-04 -1.543098e-04
0.4 -8.585386e-04 -2.449880e+01 -3.211157e-16 -8.585386e-04 8.585386e-04
0.45 -1.749605e-03 -5.990513e+01 -5.966330e-16 -1.749605e-03 1.749605e-03
0.5 -5.186319e-05 1.595486e+01 4.767925e-17 -5.186319e-05 5.186319e-05
0.55 1.543635e-04 -3.588935e+01 -3.930577e-16 1.543635e-04 -1.543635e-04
0.6 -7.612249e-04 2.186014e+01 3.930336e-17 -7.612249e-04 7.612249e-04
0.65 3.313410e-04 4.639652e+01 2.889795e-16 3.313410e-04 -3.313410e-04
0.7 2.892349e-04 2.621798e+01 1.689769e-16 2.892349e-04 -2.892349e-04
0.75 9.735677e-04 -1.517326e+00 -1.294361e-16 9.735677e-04 -9.735677e-04
0.8 -2.238232e-04 -3.281918e+00 -1.674658e-16 -2.238232e-04 2.238232e-04
0.85 2.134998e-03 3.552458e+01 1.390528e-16 2.134998e-03 -2.134998e-03
0.9 1.684388e-03 5.884333e+00 -8.721815e-17 1.684388e-03 -1.684388e-03
0.95 -7.424199e-04 4.539278e+01 2.427875e-16 -7.424199e-04 7.424199e-04
1 -1.481543e-03 -2.255855e+01 -2.944276e-16 -1.481543e-03 1.481543e-03
1.05 -1.582587e-03 -2.505637e+01 -3.293464e-16 -1.582587e-03 1.582587e-03
1.1 -8.179162e-04 2.253506e+01 6.726714e-17 -8.179162e-04 8.179162e-04
1.15 -1.319489e-03 3.004999e+01 1.292810e-16 -1.319489e-03 1.319489e-03
1.2 -1.192611e-03 -2.039599e+01 -2.585416e-16 -1.192611e-03 1.192611e-03
1.25 -1.379565e-03 -1.013076e+01 -1.370142e-16 -1.379565e-03 1.379565e-03
1.3 6.314464e-04 1.041990e+01 -4.245293e-17 6.314464e-04 -6.314464e-04
1.35 -7.855393e-04 7.819462e+01 5.326010e-16 -7.855393e-04 7.855393e-04
1.4 -2.026940e-03 3.335260e+01 1.830789e-16 -2.026940e-03 2.026940e-03
1.45 -5.432268e-03 1.905791e+01 6.719342e-17 -5.432268e-03 5.432268e-03
1.5 -4.095904e-03 -3.961749e+01 -4.103964e-16 -4.095904e-03 4.095904e-03
1.55 -1.168909e-04 4.603047e+00 -5.514416e-17 -1.168909e-04 1.168909e-04
1.6 5.805177e-03 3.819683e+01 2.081643e-16 5.805177e-03 -5.805177e-03
1.65 6.791586e-03 -4.846155e+01 -4.837928e-16 6.791586e-03 -6.791586e-03
1.7 8.073238e-03 -6.908144e+00 -1.649426e-16 8.073238e-03 -8.073238e-03
The following is my code
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 7
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (1 0 0);
boundaryField
inlet
type turbulentInlet;
referenceField uniform (1 0 0);
fluctuationScale (0.01 0.01 0);
outlet
type zeroGradient;
topwall
type symmetryPlane;
bottomwall
type symmetryPlane;
cylinder
type fixedValue;
value uniform (0 0 0);
front
type empty;
back
type empty;
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
topwall
type symmetryPlane;
bottomwall
type symmetryPlane;
cylinder
type zeroGradient;
front
type empty;
back
type empty;
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
object nuTilda;
dimensions [0 2 -1 0 0 0 0];
boundaryField
inlet
type fixedValue;
value uniform 0;
outlet
type zeroGradient;
topwall
type symmetryPlane;;
bottomwall
cylinder
type fixedValue;
value uniform 0;
front
type empty;
back
type empty;
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
location "0";
object nut;
boundaryField
inlet
type calculated;
value uniform 0;
outlet
type calculated;
value uniform 0;
topwall
type symmetryPlane;
value uniform 0;
bottomwall
type symmetryPlane;
value uniform 0;
cylinder
type calculated;
value uniform 0;
front
type empty;
back
type empty;
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
location "0";
object k;
// k = 3/2*(Uref * I)^2 = 0.002159
// I = 0.16*Re^(-1/8)= 0.03794
internalField uniform 0.002159;
boundaryField
inlet
type fixedValue;
value uniform 0.002159;
outlet
type zeroGradient;
topwall
type symmetryPlane;
bottomwall
type symmetryPlane;
cylinder
type fixedValue;
value uniform 0.0;
front
type empty;
back
type empty;
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object transportProperties;
transportModel Newtonian;
nu [0 2 -1 0 0 0 0] 1e-05;
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class dictionary;
object turbulenceProperties;
simulationType LES;
LES
LESModel Smagorinsky;
turbulence on;
printCoeffs on;
delta cubeRootVol;
dynamicKEqnCoeffs
filter simple;
cubeRootVolCoeffs
deltaCoeff 1;
PrandtlCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
smoothCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
maxDeltaRatio 1.1;
Cdelta 0.158;
vanDriestCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
smoothCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
maxDeltaRatio 1.1;
Aplus 26;
Cdelta 0.158;
smoothCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
maxDeltaRatio 1.1;
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSchemes;
ddtSchemes
default backward;
gradSchemes
default leastSquares;
divSchemes
default none;
div(phi,U) Gauss linear;
div(phi,k) Gauss linear;
div(phi,B) Gauss linear;
div(phi,nuTilda) Gauss linear;
div(B) Gauss linear;
div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear limited 1;
interpolationSchemes
default linear;
snGradSchemes
default limited 1;
fluxRequired
default no;
p ;
wallDist
method meshWave;
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSolution;
solvers
p
solver PCG;
preconditioner DIC;
tolerance 1e-7;
relTol 0;
pFinal
$p;
relTol 0;
"(U.*|k.*|B.*|nuTilda.*)"
solver PBiCG;
preconditioner DILU;
tolerance 1e-10;
relTol 0;
PISO
momentumPredictor yes;
nCorrectors 3;
nNonOrthogonalCorrectors 2;
pRefCell 0;
pRefValue 0;
relaxationFactors
fields
p 0.3;
equations
U 0.7;
k 0.7;
R 0.7;
nuTilda 0.7;
nut 0.7;
