simpleFoam is not converging at high flow rate |
Min Zhang
Rep Power: 10 ![]() |
Hello All,
I am using simpleFoam (OpenFOAM version 6.0) to solve fluid flow in porous media (also called digital rock). My simulation results could match the experimental data at low flow rate very well. But I am having issue with running high flow rate. The convergence plot is attached. More details: laminar; All the cells have the same shape (cubes) and the same volume. For the fvSchemes and fvSolution, I am mainly using the default settings from the tutorial: $FOAM_TUTORIALS/incompressible/simpleFoam/pitzDaily I tried to refine my mesh and my cell number reached 10^8. But it is still not converging. I think I will try to add turbulent model. Your comments would be greatly appreciated! Thanks! Min |
Display Modes | |
interFoam vs. simpleFoam channel flow comparison | DanM | OpenFOAM Running, Solving & CFD | 12 | January 31, 2020 15:26 |
setting OUTLET flow rate equal to INLET flow rate | spitchers | OpenFOAM Programming & Development | 0 | March 22, 2018 06:33 |
Mass flow rate boundary condition with negative values | hebe2u. | CFX | 1 | December 27, 2016 03:53 |
Flow rate restriction simulation set-up | siw | CFX | 4 | February 16, 2016 12:15 |
Target mass flow rate | Saturn | FLUENT | 0 | December 10, 2004 04:18 |
