Temperature and Velocity Limiter in rhoCentralFoam |
September 20, 2023, 08:16 |
Nick
Rep Power: 2 |
I have included in the fvoptions file the limiter of velocity and temperature in rhoCentralFoam. It's read but not applied. I want to limit temperature and velocity to avoid the solution diverging initially. Can anyone help me? Thanks, Nick Code:
limitV { type limitVelocity; active yes; selectionMode all; min 200; max 400; } limitT { type limitTemperature; active yes; selectionMode all; min 100; max 600; } |
September 25, 2023, 08:43 |
prab
Rep Power: 4 |
Hello Nick, I am also struggling with the same issue!
I learned from different sources that rhoCentralFoam does not work with fvOptions. If one wants to use fvOptions, one has to modify the source code (rhoCentralFoam.C). I am not sure how to do it properly. I have to go through the tutorials. In case if you find a way to limit the temperature, could you please post it here? Thanks you so much. |
compressible solver, divergence, limiters, rhocentralfoam, stabilization |
Import .csv - velocity profile - error | eSKa | CFX | 9 | April 3, 2021 13:38 |
Outlet temperature to temperature boundary condition of velocity inlet. (UDF) | dillon | Fluent UDF and Scheme Programming | 3 | March 25, 2018 11:06 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 17:00 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 02:13 |
