How to perform surface averaging in one direction
Like Tree3Likes
  • 1 Post By Ardali
  • 1 Post By fumiya
  • 1 Post By fumiya
Old   July 22, 2020, 10:47
Default How to perform surface averaging in one direction
chandra shekhar pant
chandra shekhar pant is on a distinguished road
Hello Foamers,
I am trying to simulate LES of aerofoil which is having 0.1 m chord length (x-axis) and 0.01 in span direction (z direction). Now I need the velocity profiles in chord-wise direction suppose at 4 locations 0.01, 0.04, 0.07 and 0.1. So I need to average in (span wise) z direction and plot the velocity profiles at these 4 locations. I am trying with line sample utility but this won't average in the z direction I guess, is there any easy way to fix this ? Any suggestion will be a great help.
chandra shekhar pant is offline   Reply With Quote
Old   July 22, 2020, 19:45
Ardalan
Ardali is on a distinguished road
hi,
have you tried 'postChannel' for your purpose. I guess it should work by the its original form otherwise you can modify the code for your sake!
Ardali is offline   Reply With Quote
Old   July 23, 2020, 01:39
Hello Ardalan,
Thanks a lot for your help, could you please elaborate something how to use it?
Old   July 23, 2020, 17:57
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
If your mesh is a structured one, you can use columnAverage function object to calculate spanwise average:
https://www.openfoam.com/documentati...mnAverage.html
Hope this helps,
Fumiya
[Personal]
fumiya is offline   Reply With Quote
Old   July 24, 2020, 09:48
Hello Fumiya,
Thanks for your help and reply but unfortunately this case don't have structured mesh. Was wondering if some kind of sampling utility is there in openFOAM which first averaged the data in z direction and then using the "linesample--type sets" can give the final data in the required line (which could be added in controlDic). Thanks again for your time and help.
Old   July 24, 2020, 22:20
fumiya's Avatar
Fumiya Nozaki
Hi Chandra,
I think there is not straightforward way in the case of unstructured meshes.
As you know, line samplings are possible using sample function in OpenFOAM.
So, the following procedure will give you approximate values:
  1. line sampling in span-wise direction
  2. calculate arithmetic mean value of sampled values
Hope this helps,
Fumiya
[Personal]
Averaging in theta direction in an annular geometry shivamswarnakar72 OpenFOAM Post-Processing 2 July 1, 2020 02:55
[snappyHexMesh] snappyHexMesh generates not planar surface krzychu111 OpenFOAM Meshing & Mesh Conversion 2 April 23, 2020 16:38
[OpenFOAM] Averaging over spatial direction in paraView Crazyman2008 ParaView 1 May 5, 2014 05:34
[CFD POST ] Averaging Values for one direction max3.2 CFX 6 May 4, 2011 14:15
Normal - Helical Surface m. malik Main CFD Forum 3 February 3, 2006 12:56
