interPhaseChangeFoam
Old   July 27, 2020, 04:40
Default interPhaseChangeFoam
Tingyun YIN
Tingyun YIN is on a distinguished road
Could anyone who successfully simulate the phase change with interPhaseChangeFoam share the experience?
OF 7.0, default interPhaseChangeFoam, 2D hydrofoil, LES;
Inlet velocity, outlet static pressure;
10 pimples, 5 pressure correction loops, 3 non-ortho corrections;
CFL is less than 0.25;
with / without relaxation factor, pressure field 0.3 while others 0.7;
However, the monitor maximum pressure has strong spikes and oscillations, not to mention of lift or drag, shown in fig. Another fig only shows the the initial residual which looks like getting convergence cause we all know the final residual will arrive the targets (1E-8).
Any comments of these spikes?
Tingyun YIN is offline   Reply With Quote
Old   August 3, 2020, 05:21
Tingyun YIN
All right, these oscillations and spikes might caused by the high order numerical schemes.
More aggressive limiters were used in the fvSchemes. Moreover, PIMPLE loops were increased up to 30.
fig shows a little improvement of the stabilization of max pressure monitored throughout the whole domain. These spikes seem to be unavoidable in the phase change field with high density ratio, especially for cloud cavitation.
Regarding the stable sheet cavity, the numerical solution of Default interPhaseChangeFoam works fine as expected.
boundary conditions? numerical schemes? Rhie-Chow interplation? limitations of density ratio as 1000? empirical coefficients of phase change model? To stabilize the pressure field, any comments of Default interPhaseChangeFoam are welcome.
Or the convergence of Default interPhaseChangeFoam is decided by 01. the residual and 02. periodical behaviors of volume integral alpha.vapour, without care of domainminandmax variables?
Strange interPhaseChangeFoam behavior after restart karamiag OpenFOAM Bugs 1 December 29, 2016 12:16
Different implementation pEqn.H in pimpleFoam vs interPhaseChangeFoam DanielRCalvete OpenFOAM Programming & Development 1 December 4, 2015 10:37
Problem with INTERPHASECHANGEFOAM shipman OpenFOAM 2 March 26, 2014 12:36
InterPhaseChangeFoam ERROR shipman OpenFOAM Running, Solving & CFD 37 March 23, 2014 12:43
Bug about MULES::implicitSolve for interPhaseChangeFoam in OF-1.6 chiven OpenFOAM Bugs 18 April 18, 2013 22:56
