Avandri |
August 7, 2020 17:13 |
Instability in buoyantSimpleFoam
Good Day Foamers
I am a little new to OpenFOAM and having bit of trouble with a project I am currently busy with. I am trying to simulate the flow around a greenhouse. buoyantSimpleFoam runs for 1 or 2 iterations when using snappyHexMesh and for about 8 or 9 iterations when using just blockMesh before I usually encounter a negative temperature and buoyantSimpleFoam stops.
Apart from using buoyantSimpleFoam the equation of state is Boussinesq and kEpsilon is being used for turbulence. I have simplified the problem into a 2D on since I did not think 3D was necessary in this case.
I have tried to check a few stability criterion and made the velocity smaller, time step smaller and mesh size larger specifically to satisfy Courant stability criterion which did help a small bit. The simulation is still unstable. I have also tried only using blockMesh without using surfaceFeatureExtract and snappyHexMesh before using buoyantSimpleFoam and it still was unstable. I have tried to use some different discretization schemes without much success. I have increased some of the relaxation factors. I believe that something in my zero folder may be causing the instability but I am learning new things every day about OpenFOAM so it may be very possible that it is something else entirely that is causing the issues I am experiencing.
When using ParaView I see that the pressure switches from high to low and back again every time step which makes me think there is an issue specifically in the p or p_rgh file in the 0 folder.
p_rgh:
boundaryField
inlet
type fixedFluxPressure;
value $internalField;
outlet
type fixedMeanOutletInlet;
meanValue 101325;
wall
ground
shell
top
type symmetry;
front
type empty;
back
type empty;
#includeEtc "caseDicts/setConstraintTypes"
p:
boundaryField
inlet
type calculated;
outlet
type calculated;
wall
type calculated;
ground
type calculated;
shell
type calculated;
top
type symmetry;
front
type empty;
back
type empty;
U:
boundaryField
inlet
type fixedValue;
value uniform $Uinlet;
outlet
type inletOutlet;
inletValue $internalField;
wall
type noSlip;
ground
type noSlip;
shell
type noSlip;
top
type symmetry;
front
type empty;
back
type empty;
T:
boundaryField
outlet
type inletOutlet;
inlet
type fixedValue;
wall
type fixedValue;
value uniform 300;
ground
type fixedValue;
value uniform 300;
shell
type fixedValue;
value uniform 300;
top
type symmetry;
front
type empty;
back
type empty;
k:
boundaryField
inlet
type fixedValue;
outlet
type inletOutlet;
wall
type kqRWallFunction;
ground
shell
top
type symmetry;
front
type empty;
back
type empty;
epsilon:
boundaryField
inlet
type fixedValue;
outlet
type inletOutlet;
wall
type epsilonWallFunction;
ground
shell
top
type symmetry;
front
type empty;
back
type empty;
alphat:
boundaryField
inlet
type calculated;
value uniform 0.12;
outlet
type inletOutlet;
wall
type compressible::alphatJayatillekeWallFunction;
Prt 0.85;
value uniform 0.12;
ground
Prt 0.85;
value uniform 0.12;
shell
Prt 0.85;
value uniform 0.12;
top
type symmetry;
front
type empty;
back
type empty;
nut:
boundaryField
inlet
type calculated;
value uniform 0;
outlet
type inletOutlet;
wall
type nutkWallFunction;
value uniform 0;
ground
value uniform 0;
shell
value uniform 0;
top
type symmetry;
back
type empty;
front
type empty;
And finally here is a link to two cases I have made with what I have so far. One with only blockMesh and buoyantSimpleFoam and the other run with all the required bits of the simulation:
https://drive.google.com/drive/folde...0z?usp=sharing
Sorry for the large post. I would truly be incredibly grateful to any help I can get on this issue
