type expression with variables leads into error message
Old   August 12, 2020, 03:15
Default type expression with variables leads into error message
Siassei is on a distinguished road
in the phaseProperties dict I will set a temperatureDependent surfaceTension with expression value.
Variable Def
Expression usage
Quick example
surfaceTension
    (gas and liquid)
        type            temperatureDependent;
        sigma
            sigma
                type expression;
                variables
                    "B = 1"
                    "Tc = 2"
                expression
                    arg() * Tc + B
I get the followed error. (If I remove the variables definition and subsitute the variables into the expression than everything works)
running decomposePar on /data
[0] [3]
[3]
[3] --> FOAM FATAL IO ERROR:
[3] Expected a '(' while reading Tuple2, found on line 0: error
[3]
[3]
[3] file: IOstream at line 0.
[3]
[3]     From bool Foam::Istream::readBegin(const char*)
[3]     in file db/IOstreams/IOstreams/Istream.C at line 116.
[3]
FOAM parallel run exiting
I use the solver
icoReactingMultiphaseInterFoam -version
Using: OpenFOAM-v2006 (2006) - visit www.openfoam.com
Build: 5dc04530d9-20200714
Siassei is offline   Reply With Quote
Old   August 12, 2020, 08:37
I had fixed.
Remove the first type qualif.
(remove line 5 of my short example)
Old   September 14, 2020, 07:31
Default Temperature Dependent Surface Tension
Bill
OPFO is on a distinguished road
Hi Thomas,
Thank you for sharing your code for temperature dependent surface tension!
Do you know how to call the solid volume fraction in the icoReactingMultiphaseInterFoam solver for use in an equation (e.g. TEqn)?
In Interfoam, it is simply alpha1 or alpha2, but due to the multiphase nature of the icoReactingMultiphaseInterFoam solver, everything is kind of confusing because of phase pairs and the entire fluid references.
Any help is appreciated!
OPFO is offline   Reply With Quote
Old   October 9, 2021, 04:04
Pavithra is on a distinguished road
Variable Def
Expression usage
Quick example
surfaceTension
    (gas and liquid)
        sigma
            sigma
                type expression;
                variables
                    "B = 1"
                    "Tc = 2"
                expression
                    arg() * Tc + B
[0] [3]
[3]
[3]
[3]
[3]
[3]
I use the solver
Thanks for sharing ur expression.
Could you please explain what does arg() means in your expression ?
Thank you.
Pavithra is offline   Reply With Quote
Old   February 2, 2022, 12:12
rupak504's Avatar
Lolita
rupak504 is on a distinguished road
Thank you.
have you figured out what is that arg() for? my first guess would be temperature.
rupak504 is offline   Reply With Quote
Old   February 2, 2022, 13:04
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
The 'arg()' in the expression simply represents the argument 'x' passed into a Function1 value(const scalar x)
https://www.openfoam.com/documentati...Function1.html
olesen is offline   Reply With Quote
Instability in buoyantSimpleFoam Avandri OpenFOAM Running, Solving & CFD 0 August 7, 2020 17:13
[Other] simulation of closing the gate using moving mesh simin_ds OpenFOAM Meshing & Mesh Conversion 8 April 12, 2019 06:49
rSF: p divergence in combustor (wt negative value) zonda OpenFOAM Pre-Processing 4 April 10, 2018 07:59
time step continuity problem in VAWT simulation lpz_michele OpenFOAM Running, Solving & CFD 5 February 22, 2018 20:50
Divergent temperature in chtMultiRegion(Simple)Foam akrasemann OpenFOAM Running, Solving & CFD 13 March 24, 2014 03:54
