nikhil108 |
August 24, 2020 16:32 |
Dynamic mesh (AMR), dynamicRefineFvMesh
Hallo foamers,
I am trying to run a case, the domain is created using blockMesh, then using snappyhex, geometry of the body is captured with stl. I didn't used any refinement levels too. I tried using different settings in snappyHex, but I keep on getting this following error.
--> FOAM FATAL ERROR:
Celllevel does not satisfy 2:1 constraint.
On face 76826 owner cell 25718 has refinement 0 neighbour cell 26964 has refinement 2
From function void Foam::hexRef8::checkRefinementLevels(Foam::label, const labelList&) const
in file polyTopoChange/polyTopoChange/hexRef8/hexRef8.C at line 4851.
everything runs fine when I just use renumber mesh and run the solver from latest time step, but when I use renumbermesh -overwrite then I am getting above error. Below is my snappyhexdict. Please share your thoughts.
castellatedMesh true;
snap false;
addLayers false;
geometry
pump.stl
type triSurfaceMesh;
name walls;
inlet1.stl
name inlet;
box1 //refine porous
type searchableBox;
min (-0.47 -0.27 -0.47);
max (0.47 -0.22 0.47);
box2 //refine hole
type searchableBox;
min (-0.05 -0.05 -0.58);
max (0.05 0.05 -0.48);
castellatedMeshControls
maxLocalCells 100000;
maxGlobalCells 2000000;
minRefinementCells 10;
maxLoadUnbalance 0.10;
nCellsBetweenLevels 1;
features
refinementSurfaces
inlet { level (1 2); patchInfo { type patch; }}
walls { level (1 2); patchInfo { type wall; }}
resolveFeatureAngle 30;
refinementRegions
/*box1
mode inside;
levels ((0 2));
box2
mode inside;
levels ((0 2));
locationInMesh (0.15 0.12 0.11);
allowFreeStandingZoneFaces true;
snapControls
nSmoothPatch 3;
tolerance 2.0;
nSolveIter 30;
nRelaxIter 5;
nFeatureSnapIter 10;
implicitFeatureSnap false;
//- Use castellatedMeshControls::features (default = true)
explicitFeatureSnap true;
//- Detect points on multiple surfaces (only for explicitFeatureSnap)
multiRegionFeatureSnap false;
addLayersControls
relativeSizes true;
layers
expansionRatio 1.0;
finalLayerThickness 0.3;
minThickness 0.1;
meshQualityControls
#include "meshQualityDict"
// Advanced
//- Number of error distribution iterations
nSmoothScale 4;
//- Amount to scale back displacement at error points
errorReduction 0.75;
I tried turning snap on, and used refinements, did changes in geometry.
I am out of ideas:confused:, what am I doing wrong, any ideas to troubleshoot this?
Thankyou,
cheers,
nikhil.
