rhoSimpleFoam with specified mass flow rate at outlet
Hello.
I want to run a subsonic compressible flow inside a duct. I am essentially trying to replicate the boundary conditions used in experimental setup through OpenFOAM 7.0. For the outlet of the system, the mass flow rate has been provided and at the inlet total pressure/total temperature as been provided. For the specified mass flow rate, I want to use flowRateOutletVelocity. But I am confused as to what parameters have to be actually defined in the BC definition. I used Code:
foamInfo -FlowRateOutletVelocity Code:
Velocity outlet boundary condition which corrects the extrapolated velocity I want to use the mass flow rate definition. I have referred to the discussion here but there seems to be no conclusion: https://www.cfd-online.com/Forums/op...plication.html Finally, how can I initialize my rhoSimpleFoam solution ? Do you suggest running first in simpleFoam and then running rhoSimpleFoam ? If I do this, will I have to change the boundary conditions ? Some information on this will be helpful. |
If you use a solver for incompressible flows like simpleFoam which does not have a density field, you have to specify rho with the rhoOutlet key word. If you use a solver for compressible flows, e.g. buoyantPimpleFoam, then you must specify the name of the density field, which in then would be rho.
In case Joachim's response is not 100% clear, take a look at the "Detailed Description" of the Doxygen entry for the BC: https://cpp.openfoam.org/v8/classFoa...d.html#details.
You are using rhoSimpleFoam, i.e. a compressible solver with a density field that has the default name "rho", so if I am reading it right you should be able to ignore the rho and rhoOutlet parameters and just define the massFlowRate, viz: Code:
<patchName> |
Thanks for the information. For simpleFoam if I ignore any of the rho related parameters, then volumetric flow rate has to be specified. So let's say that my m_dot is 4 kg/s and my density is 2 kg/m3. If I am understanding it right, for simpleFoam, I will have to use m_dot / 2 = 2 m3/s. Or can I just use the actual m_dot value ? I know that for in compressible flows, OF uses kinematic pressure and hence the density term doesn't come into the picture.
I am still not sure what does Code:
rho rho; In the same documentation link, it mentions that rhoOutlet entry needs to be provided(for rhoSimpleFoam run) if the density field is not available at start-up. Density field will of course not be available at start-up because that's what I want to solve for. In that case I will have to give the density value using the rhoOutlet parameter right ? The issue is that I don't have this value. I have tried to make some estimations using 1D isentropic flow calculations but in vain. There is simply not enough information available. The only information I have from experimental setup is total pressure/temperature at duct inlet, Mach number at a location upstream of outlet, and finally mass flow rate at outlet. |
