Defining a polynomial viscosity depending on temperature
Hello all,
I'm currently trying to run an analysis using temperature integrated simpleFoam. As of my observations, temperature range for the fluid is between 20-50 C and due to this large range, viscosity changes in a wide range which leads my computation into a big error, at about 50%. So here is my question. I would like to apply a curve-fitting to viscosity of my fluid flowing through and integrate it in the OpenFOAM by NOT using a non-Newtonian approach. Because fluid is definetely Newtonian. How can I achieve it? |
There are more options. Either you switch to, e.g., rhoSimpleFoam and use a polynomial approach or you derive your current solver (simpleFoam) and implement new volScalarFieldīs which relates to temperature and viscosity. Then you have to solve an appropriate temperature/energy equation and calculate the viscosity based on your temperature field.
Probably, the rhoSimpleFoam solver fits better as you donīt have to program anything yourself. An example: Code:
thermoType |
Thank you for your reply Tobi,
The thing is I would like to compute the viscosity for each cell using its temperature and have this value used in governing equations. I don't want any contour for viscosity, to say. Do you have any recommendation for this goal? Quote:
Well, I am not sure if you read my reply or not because I wrote the stuff you need. Hence, I don't get your statement.
Thank you for your help and kindness.
Just a quick question. Is it clear to you now or not? I don't have the feeling that my statement is sufficient for you or maybe I misunderstood your inquiry!?
