-   OpenFOAM Running, Solving & CFD (https://www.cfd-online.com/Forums/openfoam-solving/)
-   -   Adding helium gas into shock tube driver section (https://www.cfd-online.com/Forums/openfoam-solving/230813-adding-helium-gas-into-shock-tube-driver-section.html)
spkumar October 7, 2020 07:16
2 Attachment(s)
Hi all,
I am solving a detonation problem in a shock tube. For that, I am using Hydrogen-Oxygen reaction mechanism from chemFoam tutorial. This reaction mechanism involves 10 species and 27 reactions.
I want to introduce Helium gas into the driver section of the shock tube. Basically, I am adding a new species into the multi species reactive system. The following changes that I have made to the test case:
1. Copied the "He" thermodynamics data from etc/thermoData/thermoData
2. Added the thermo data in the constant/thermo.compressibleGas
3. Added "He" in the 'elements' and 'species' section of the constant/reactions file.
4. added Helium in the time directory
I am following this paper to validate my solver: https://www.sciencedirect.com/scienc...10465517301637. I think there is no requirement of communicating Helium gas information added to the reaction set which I can see from the reaction mechanism mentioned in the paper. Then, How it is going to act like safer system (inert gas addition) ?
I have attached a png file which has terminal message. I was not able rectify the issue. do I need to make any changes to resolve IO Error? Could you please give any suggestions ?
Thanks & Regards
dasith0001 December 7, 2021 23:55
Hi SpKumar,
Could you please share the 'thermophysicalProperties' data used for He ?
I am running a simple heat transfer model with He as the convective medium.
Thank you
Dasith
