OpenFoam Stopped without error message twoPhaseEulerFoam |
October 16, 2020, 00:33 |
Sumit Peh
Rep Power: 7 |
Hi Foamer !
I searched and solved many errors on my case in this community, but I didn't found the solution on this case. I'm running modified bubble column case with my own geometry. I used the setup case from bubble column tutorial in openfoam, mesh by the cfmesh with .fms geometry file and modified the meshDict, setFieldsDict, g(correct z axis),d0(bubble size), controlDict(Endtime 60s). Everything seems to run smoothly on the cartesianMesh, SetFields and even the twoPhaseEulerFoam. But it randomly stopped at "Constructing momentum equations" here is the end part of the terminal. Code:
Courant Number mean: 0.192367 max: 54.0446 Max Ur Courant Number = 34.4552 Time = 6.825 PIMPLE: iteration 1 MULES: Solving for alpha.air MULES: Solving for alpha.air alpha.air volume fraction = 0.251251 Min(alpha.air) = -1.23474e-20 Max(alpha.air) = 1.06091 Constructing momentum equations smoothSolver: Solving for e.air, Initial residual = 0.993034, Final residual = 5.72382e-05, No Iterations 1000 smoothSolver: Solving for e.water, Initial residual = 0.900522, Final residual = 0.00115984, No Iterations 1000 min T.air 296.75 min T.water 299.824 GAMG: Solving for p_rgh, Initial residual = 0.00734846, Final residual = 3.66422e-09, No Iterations 9 PIMPLE: iteration 2 MULES: Solving for alpha.air MULES: Solving for alpha.air alpha.air volume fraction = 0.251258 Min(alpha.air) = -2.51025e-21 Max(alpha.air) = 1.02043 Constructing momentum equations smoothSolver: Solving for e.air, Initial residual = 0.29879, Final residual = 0.0027419, No Iterations 1000 smoothSolver: Solving for e.water, Initial residual = 0.665088, Final residual = 0.00319244, No Iterations 1000 min T.air 296.691 min T.water 299.824 GAMG: Solving for p_rgh, Initial residual = 0.00326417, Final residual = 4.35379e-09, No Iterations 8 PIMPLE: iteration 3 MULES: Solving for alpha.air MULES: Solving for alpha.air alpha.air volume fraction = 0.251249 Min(alpha.air) = -7.92949e-21 Max(alpha.air) = 1.20173 Constructing momentum equations smoothSolver: Solving for e.air, Initial residual = 0.21708, Final residual = 0.00331834, No Iterations 1000 smoothSolver: Solving for e.water, Initial residual = 0.178944, Final residual = 0.00354534, No Iterations 1000 min T.air 295.475 min T.water 301.303 GAMG: Solving for p_rgh, Initial residual = 0.00583616, Final residual = 8.10231e-09, No Iterations 9 bounding km, min: 9.94883e-16 max: 19599.2 average: 50.575 bounding epsilonm, min: 2.0515e-21 max: 5.27789e+07 average: 30345.7 smoothSolver: Solving for epsilonm, Initial residual = 0.000395396, Final residual = 8.97474e-08, No Iterations 22 bounding epsilonm, min: -9904.44 max: 5.27789e+07 average: 39637.7 smoothSolver: Solving for km, Initial residual = 2.44555e-09, Final residual = 3.26389e-10, No Iterations 1 bounding km, min: -0.562915 max: 16106.6 average: 153.064 ExecutionTime = 115.67 s ClockTime = 121 s fieldAverage fieldAverage1 write: Calculating averages Courant Number mean: 0.447823 max: 54.8887 Max Ur Courant Number = 369.284 Time = 6.83 PIMPLE: iteration 1 MULES: Solving for alpha.air MULES: Solving for alpha.air alpha.air volume fraction = 0.251188 Min(alpha.air) = -3.96738e-21 Max(alpha.air) = 1.36108 Constructing momentum equations smoothSolver: Solving for e.air, Initial residual = 0.194015, Final residual = 0.00185957, No Iterations 1000 smoothSolver: Solving for e.water, Initial residual = 0.00960397, Final residual = 9.90323e-08, No Iterations 328 min T.air 191.056 min T.water 301.337 GAMG: Solving for p_rgh, Initial residual = 0.0732878, Final residual = 4.43483e-09, No Iterations 11 PIMPLE: iteration 2 MULES: Solving for alpha.air MULES: Solving for alpha.air alpha.air volume fraction = 0.251121 Min(alpha.air) = -7.1303e-22 Max(alpha.air) = 4.08928 Constructing momentum equations smoothSolver: Solving for e.air, Initial residual = 0.981585, Final residual = 9.4538e-08, No Iterations 126 smoothSolver: Solving for e.water, Initial residual = 0.0150729, Final residual = 6.45716e-07, No Iterations 1000 min T.air -2387.77 min T.water 286.602 GAMG: Solving for p_rgh, Initial residual = 0.60359, Final residual = 5.60784e-09, No Iterations 17 PIMPLE: iteration 3 MULES: Solving for alpha.air MULES: Solving for alpha.air alpha.air volume fraction = -1.31932 Min(alpha.air) = -3583.82 Max(alpha.air) = 11737.8 Constructing momentum equations jameslinux@DESKTOP-XXXXXX:~/Practice_files/bbccaselessmesh$ ps. my drive space still has 30 GB left, if that the reason. Thank you Foamer |
October 16, 2020, 02:05 |
Yogesh Bapat
Rep Power: 15 |
If you look at log and volume fraction values at the end min value is negative and max value is much greater than 1. The case has diverged and may have got a floating point exception. |
October 16, 2020, 08:57 |
#3 | |
Sumit Peh
Rep Power: 7 |
but yet, I still got another problem to fixed on Negative initial temperature T0. I'll try to fix it and post the solution on my next thread if i possible to manage it. remarks for others : check the g, U.air in the correct axis // p p_rho with 1e5. |
cfd, crash, openfoam, simulation cfd, twophaseeulerfoam |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 08:51 |
twoPhaseEulerFoam validation OpenFOAM 4.1 | jiejie | OpenFOAM Running, Solving & CFD | 4 | April 20, 2019 03:06 |
OpenFOAM 4.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 2 | October 6, 2017 05:40 |
OpenFOAM Training: Programming CFD Course 12-13 and 19-20 April 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 14, 2016 10:19 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 05:56 |
