March 10, 2020, 16:49 |
high continuity error rhoSimpleFoam
james freak
Rep Power: 6 |
I'm quite new on OpenFoam and I am using rhoSimpleFoam to get a steady state flow of a supersonic nozzle. Problem is that I have huge continuity errors and P residuals are high, here are the first and last output of log: Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: Convergence criteria found "(p|U|e|h)": tolerance 1e-05 Reading thermophysical properties Selecting thermodynamics package { type hePsiThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } Reading field U Reading/calculating face flux field phi pressureControl pMax 2.46615e+07 pMin 245803 Creating turbulence model Selecting turbulence model type laminar Selecting laminar stress model Stokes No MRF models present No finite volume options present Starting time loop Time = 10 smoothSolver: Solving for Ux, Initial residual = 0.000126502, Final residual = 4.31626e-11, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.000567908, Final residual = 5.70707e-14, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 1.0017e-05, Final residual = 2.56742e-12, No Iterations 2 smoothSolver: Solving for e, Initial residual = 6.16089e-06, Final residual = 1.45283e-12, No Iterations 2 smoothSolver: Solving for p, Initial residual = 0.994916, Final residual = 0.0496945, No Iterations 352 smoothSolver: Solving for p, Initial residual = 0.0313108, Final residual = 0.012273, No Iterations 1000 time step continuity errors : sum local = 1558.25, global = 877.153, cumulative = 877.153 pressureControl: p min -80834.6 ExecutionTime = 0.1 s ClockTime = 0 s functionObjects::MachNo MachNo writing field: Ma Time = 1000 smoothSolver: Solving for Ux, Initial residual = 0.000147395, Final residual = 6.08258e-12, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.000566841, Final residual = 6.28291e-13, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 2.53193e-05, Final residual = 7.40255e-13, No Iterations 2 smoothSolver: Solving for e, Initial residual = 1.84346e-05, Final residual = 6.97073e-13, No Iterations 2 smoothSolver: Solving for p, Initial residual = 0.989533, Final residual = 0.334296, No Iterations 1000 smoothSolver: Solving for p, Initial residual = 0.0415304, Final residual = 0.0396437, No Iterations 1000 time step continuity errors : sum local = 30545.9, global = 30254.8, cumulative = 1.56395e+06 pressureControl: p min -1.71007e+07 ExecutionTime = 6.01 s ClockTime = 6 s functionObjects::MachNo MachNo writing field: Ma End I have try with really low relaxation factor, otherwise, the simulation crash early. Initial conditions comes from a simulation done with a transient solver (rhoCentralFoam). Where does this problem come from? Does some solvers are better than other for that kind of problem? Thank you for your help. controlDict Code:
application rhoSimpleFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 1000; deltaT 10; writeControl timeStep; writeInterval 1; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; graphFormat raw; runTimeModifiable true; adjustTimeStep yes; maxCo 0.5; maxDeltaT 1; functions { #includeFunc MachNo #includeFunc residuals } fvSolution Code:
solvers { p { // solver GAMG; solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-8; relTol 0.05; nCellsInCoarsestLevel 50; } "(U|e)" { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-7; relTol 0.1; } } SIMPLE { nNonOrthogonalCorrectors 1; pMinFactor 0.1; pMaxFactor 10; residualControl { "(p|U|e|h)" 1e-5; } } relaxationFactors { fields { "(p|rho)" 0.001; } equations { "(p|U|e)" 0.001; "(p|U|e)Final" 1; } } // ************************************************************************* // fvSchemes Code:
ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss upwind; div(phi,e) bounded Gauss upwind; div(phi,epsilon) bounded Gauss upwind; div(phi,k) bounded Gauss upwind; div(phi,Ekp) bounded Gauss upwind; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } |
November 4, 2020, 23:45 |
ishan
Rep Power: 8 |
Hello.
Were you able to find a solution to this problem ? |
How to use PIMPLE properly? | floquation | OpenFOAM Running, Solving & CFD | 25 | December 2, 2021 09:40 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
time step continuity problem in VAWT simulation | lpz_michele | OpenFOAM Running, Solving & CFD | 5 | February 22, 2018 19:50 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 07:47 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
