"decomposePar" not decomposing volumeVectorField located inside user defined folder |
December 11, 2020, 01:32 |
Krishna
Rep Power: 9 |
Hello All,
I have to read volumeVectorField variables from a folder named “B”. This folder contains the magnetic field distribution files (i.e. B_0.1, B_0.2, B_0.3………. so on) at different time. I will use different file at different time in the solution. I want to run the solver in parallel. But, when I use “decomposePar”, the decomposition does not happen to the files located inside the folder “B”. Can anyone comment on how to decompose the files located inside user defined folders (In my case that folder is “B”)? |
decomposepar, external folder, parallel computaion, volumevectorfield |
Display Modes | |
Regarding DEFINE_VR_RATE and DEFINE_SR_RATE user defined functions in fluent | ajithjec | FLUENT | 0 | November 6, 2020 05:36 |
Assigning source terms in user defined memory which is located at the interface? | vidyadhar | Fluent UDF and Scheme Programming | 0 | November 20, 2018 08:06 |
[General] Paraview User defined view | prapanj | ParaView | 3 | January 3, 2014 20:54 |
user defined turbulence model | manuutin | STAR-CD | 5 | October 14, 2009 05:29 |
UDF - Derivatives for User Defined Memory Variable | Sandilya Garimella | FLUENT | 0 | January 14, 2008 10:39 |
