September 23, 2020, 04:21 |
Drag Model for twoPhaseEulerFoam
Patrizio
Rep Power: 7 |
Good morning everyone,
I would like to know if it is possibile to use the "PlessisMasliyahDrag particleForce" in an eulerian-eulerian solver like twophaseeulerfoam. The goal is to find the best drag model to match experimental data of metal particle injected in a convergent divergent supersonic nozzle (the continuum media is gas). Otherwise are there other suggestions about other drag model? Thank you. Patrizio |
September 29, 2020, 06:19 |
Rep Power: 8 |
if you go to
solvers -> multiphase -> twoPhaseEulerFoam -> interfacialModels -> dragModels, you will see all the available drag models for the twoPhaseEulerFoam solver. The Plessis Masliyah Drag Model is not available, but you could create a copy of the Ergun drag model and then replace the constants (150 and 1.75) with the mathematical expressions of the Plessis-Masliyah Model. |
September 29, 2020, 06:56 |
#3 | |
Patrizio
Rep Power: 7 |
Thank you very much, I will try this! |
October 1, 2020, 09:58 |
Patrizio
Rep Power: 7 |
Following your suggestion (I am not an expert in C++) I changed Ergun.c from : ________________________________ (4.0/3.0) *( 150 *max ( scalar(1) - pair_.continuous(), pair_.continuous().residualAlpha() )/max(pair_.continuous(), pair_.continuous().residualAlpha()) + 1.75 *pair_.Re() ); _____________________________________ to: return (4.0/3.0) *( ( 26.8*pow3(pair_.continuous()) /( sqr(cbrt(scalar(1) - pair_.continuous())) *(1.0 - cbrt(scalar(1) - pair_.continuous())) *sqr(1.0 - sqr(cbrt(scalar(1) - pair_.continuous()))))) *max ( scalar(1) - pair_.continuous(), pair_.continuous().residualAlpha() )/max(pair_.continuous(), pair_.continuous().residualAlpha()) + (sqr(pair_.continuous()) /sqr(1.0 - sqr(cbrt(scalar(1) - pair_.continuous())))) *pair_.Re() ); where A= (26.8*pow3(pair_.continuous()) /( sqr(cbrt(scalar(1) - pair_.continuous())) *(1.0 - cbrt(scalar(1) - pair_.continuous())) *sqr(1.0 - sqr(cbrt(scalar(1) - pair_.continuous()))) )) And B= sqr(pair_.continuous()) /sqr(1.0 - sqr(cbrt(scalar(1) - pair_.continuous()))); __________________________________________________ ____ I don't know if I well understood the variables, but it should work. There is something I should change in the .H files too ? Many thanks. Cordially, Patrizio |
October 2, 2020, 04:51 |
Rep Power: 8 |
you can't just change the equation and expect the code to work.
to make it clear i will write down the steps you need to follow: 1. create a copy of the solver you want to modify and make changes only there. if you don't know how to do it, check out the 3 weeks series, there is a tutorial on how to do that. 2. if you want to add a drag model, copy one and change i) the name of the directory, the names in the .C and .H - files. ii) change the equation 3. add your new model to the files-file in the Make-directory. look how it is done for other models and add your model. 4. compile your modified stuff whether it is the solver or the library. |
November 23, 2020, 05:57 |
#6 | |
Patrizio
Rep Power: 7 |
Thank you, following your instructions I succeeded to extend the lagrangian model to the twophaseeulerfoam euler-euler model.
Have a nice day! Quote:
Display Modes | |
Finding Drag Force from Skin Friction | Rob Wilk | Main CFD Forum | 0 | May 8, 2020 07:04 |
How to compile a new drag force in Lagrangian model | lilinmin | OpenFOAM Programming & Development | 4 | June 9, 2016 05:15 |
Drag model implementation | vbchris | OpenFOAM Running, Solving & CFD | 1 | March 31, 2015 09:28 |
about Subgrid-scale model | impecca | OpenFOAM Running, Solving & CFD | 4 | December 20, 2013 11:36 |
multiphase model and drag law | Yasmail AKARIOUH | FLUENT | 0 | April 29, 2008 08:44 |
