Modeling free-surface river connection with interIsoFoam |
November 17, 2020, 11:14 |
Grivalszki Péter
Rep Power: 7 |
Hi Foamers,
Im trying to simulate a free surface river connection using interIsoFoam.
Unfortunately, it crashes after ~0.01 s. Where is my mistake? Boundaries: U Code:
in1_w { type fixedValue; value uniform (0.5 0 0); } in1_a { type fixedValue; value uniform (0.5 0 0); } in2_w { type fixedValue; value uniform (0 -0.6 0); } in2_a { type fixedValue; value uniform (0 -0.6 0); } out { type zeroGradient; } wall { type fixedValue; value uniform (0 0 0); } RiversComplete { type fixedValue; value uniform (0 0 0); } atm { type slip; } Code:
atm { type totalPressure; p0 uniform 0; } ".*" { type fixedFluxPressure; value uniform 0; } Code:
in1_w { type fixedValue; value uniform 1; } in1_a { type fixedValue; value uniform 0; } in2_w { type fixedValue; value uniform 1; } in2_a { type fixedValue; value uniform 0; } out { type zeroGradient; value uniform 0; } atm { type inletOutlet; inletValue uniform 0; value uniform 0; } wall { type zeroGradient; } RiversComplete { type zeroGradient; } Code:
in1_w { type fixedValue; value $internalField; } in1_a { type fixedValue; value $internalField; } in2_w { type fixedValue; value $internalField; } in2_a { type fixedValue; value $internalField; } out { type zeroGradient; } wall { type kqRWallFunction; value $internalField; } atm { type inletOutlet; inletValue $internalField; value $internalField; } RiversComplete { type kqRWallFunction; value $internalField; } Code:
in1_w { type fixedValue; value $internalField; } in1_a { type fixedValue; value $internalField; } in2_w { type fixedValue; value $internalField; } in2_a { type fixedValue; value $internalField; } out { type zeroGradient; } wall { type epsilonWallFunction; value $internalField; } atm { type inletOutlet; inletValue $internalField; value $internalField; } RiversComplete { type epsilonWallFunction; value $internalField; } Code:
in1_w { type calculated; value uniform 0; } in1_a { type calculated; value uniform 0; } in2_w { type calculated; value uniform 0; } in2_a { type calculated; value uniform 0; } wall { type nutkWallFunction; value uniform 0; } RiversComplete { type nutkWallFunction; value uniform 0; } out { type zeroGradient; } atm { type calculated; value uniform 0; } |
channel water flow, free surface flow, interisofoam, multiphase flow, river |
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? | EternalSeekerX | SU2 | 3 | October 9, 2020 18:28 |
Problem in free surface modeling of water-oil mixture | scythe | FLUENT | 4 | November 12, 2013 11:47 |
Which code to go for free surface wave modeling.. | Ted Chu | Main CFD Forum | 7 | December 29, 2008 15:42 |
Hydrofoil modeling near free surface in fluent | Mojtaba Lajevardi | FLUENT | 2 | June 7, 2008 04:59 |
Modeling Free Surface Flows | Elliot Schwartz | Main CFD Forum | 5 | August 25, 1998 21:03 |
