Smoothing of IDDES delta
Old   July 15, 2013, 11:53
Default Smoothing of IDDES delta
Marian Fuchs
Fuchs is on a distinguished road
Dear OpenFOAM users,
I am trying to test IDDES models for snappyHexMesh grids including 2:1 jumps in cell size in OpenFOAM-2.2.0. For this reason, I'd like to test the smoothing option for the delta used by the IDDES model. For DES97 and DDES, this works just fine, where delta is defined in LESProperties, e.g.:
delta smooth;
smoothCoeffs
delta maxDeltaxyz;
maxDeltaxyzCoeffs
deltaCoeff 2;
maxDeltaRatio 1.2;
I tried to convert the syntax for the IDDES delta as follows:
IDDESmodelCoeffs
delta smooth;
smoothCoeffs
delta IDDESDelta;
IDDESDeltaCoeffs
cw 0.15;
deltaCoeff 1;
maxDeltaRatio 1.2;
cdt1 8;
delta maxDeltaxyz;
maxDeltaxyzCoeffs
deltaCoeff 2;
Unfortunately, this leads to an infinite loop when I start my computation. Here is an excerpt of my log file:
Create time
Create mesh for time = 80
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type LESModel
Selecting LES turbulence model IDDESmodel
Selecting LES delta type smooth
Selecting LES delta type maxDeltaxyz
IDDESmodelCoeffs
delta smooth;
smoothCoeffs
delta IDDESDelta;
IDDESDeltaCoeffs
cw 0.15;
deltaCoeff 1;
maxDeltaRatio 1.2;
Selecting LES delta type IDDESDelta
Maybe someone of you has already stumbled about this problem and can share his experience/the correct delta smoothing settings in this thread.
Thanks in advance,
Marian
Fuchs is offline   Reply With Quote
Old   October 11, 2018, 23:03
zhangyan's Avatar
Yan Zhang
zhangyan is on a distinguished road
Hi, Did you solve this problem?
zhangyan is offline   Reply With Quote
Old   November 17, 2020, 11:17
Default Still an issue
Magnus Johannesen
magjo is on a distinguished road
Hey, did anyone solve this? I'm also getting the same issue with both kOmegaSSTDES and SpalartAllmarasDES with all the different delta types.
Running Openfoam-dev/200402
Edit: Got it to work properly with the full set of coefficents.
magjo is offline   Reply With Quote
[ANSYS Meshing] Smoothing options siw ANSYS Meshing & Geometry 3 August 13, 2019 07:40
Delta wing cfd H_R FLUENT 16 September 19, 2013 04:41
[ANSYS Meshing] Smoothing and Post Smoothing siw ANSYS Meshing & Geometry 0 November 5, 2012 09:14
IDDES delta cfdmarkus OpenFOAM Bugs 1 July 17, 2012 04:28
Hexa smoothing (ICEM CFD 10.0) CFDworker CFX 3 November 2, 2005 10:23
