November 18, 2020, 07:45 |
k-Epsilon Spurious Outlet
Tony Zahtila
Rep Power: 10 |
Hi all,
I am trying to simulate a chamber with an outlet, and a mouth inside the chamber. The problem I am having is that I am trying to obtain a steady solution with the SIMPLE method, but my solution is not converging even after 20,000 iterations. Further, the velocity, k and Epsilon field are all kind 'splotchy'. I should further add, that the epsilon field reaches values of ~100, which are higher than the boundary condition I set on it of 0.025. Setup In the following three images, the outlet is the solid blue ring. There are zero-gradient interfaces with the atmosphere, depicted in white. Lastly, the mouth is the following 'disc'. U Field: Epsilon Field: |
November 18, 2020, 07:49 |
Tony Zahtila
Rep Power: 10 |
My epsilon, k and U files are as follows:
Epsilon Code:
dimensions [0 2 -3 0 0 0 0]; internalField uniform 0.025; boundaryField { walls { type epsilonWallFunction; Cmu 0.09; kappa 0.41; E 9.8; value uniform 0.125; } inlet { type zeroGradient; } mouth { // type zeroGradient; type fixedValue; value $internalField; } outlet { type inletOutlet; inletValue uniform 0.025; value uniform 0.375; } } Code:
dimensions [0 2 -2 0 0 0 0]; internalField uniform 0.00375; boundaryField { walls { type kqRWallFunction; value uniform 0.375; } inlet { type zeroGradient; } mouth { type zeroGradient; } outlet { type zeroGradient; } } Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { walls { type fixedValue; value uniform (0 0 0); } outlet { type flowRateOutletVelocity; volumetricFlowRate 0.04; // 50/3600 // Volumetric/mass flow rate [m3/s or kg/s] value uniform (0 0 0); // placeholder } mouth { type flowRateInletVelocity; volumetricFlowRate 0.002; // 50/3600 // Volumetric/mass flow rate [m3/s or kg/s] value uniform (0 0 0); // placeholder } inlet { type zeroGradient; } } } Code:
dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { walls { type zeroGradient; // value 0; } outlet { type zeroGradient; // value 0; } inlet { type fixedValue; value uniform 0; } mouth { type zeroGradient; // value 0; } Any advice on the following questions would be appreciated: a) Whether it is normal to see such a high epsilon value given that it lies outside the boundary value and the remaining boundaries are zero value? If a) is not normal, any insight to what I might be doing wrong. Kind regards. Last edited by tzaht; November 27, 2020 at 00:19. |
November 27, 2020, 00:16 |
Tony Zahtila
Rep Power: 10 |
Hi all,
I have a further update, and have tried to pose this question as briefly as possible. I essentially have a chamber, in which there is an outlet whereby I fix the outflow. I also have an inflow from within the domain, where I have annotated 'mouth'. As there is a balance between total mass flux, I have left the 'inlet' as zeroGradient, and so flow should be coming from the outside environment into the chamber to balance the mass (incompressible flow). In this particular image, I have no turbulence model, but no matter what turbulence model I have, I get these numerical blow-ups occurring near the outlet. I have tried all the various gradient schemes I have seen posted on cfd-online. Any advice appreciated, as I am struggling to understand what is going wrong and have run out of ideas. |
the value of k and Epsilon is constantly increasing | saidc. | OpenFOAM Running, Solving & CFD | 6 | April 23, 2020 22:35 |
natural convection in square cavity having inlet and outlet | sujeet | OpenFOAM Running, Solving & CFD | 1 | November 2, 2019 02:17 |
A ghost like outlet appears in my model | minecraftgp | OpenFOAM Running, Solving & CFD | 5 | August 31, 2018 11:37 |
twoPhaseEulerFoam bubble column crashes due to problems at outlet region | hester | OpenFOAM Running, Solving & CFD | 4 | May 18, 2016 10:20 |
Pressure Outlet Guage pressure | Mohsin | FLUENT | 36 | April 29, 2016 17:16 |
