-   OpenFOAM Running, Solving & CFD (https://www.cfd-online.com/Forums/openfoam-solving/)
-   -   How to control transient solution by max iterations/per time step in Openfoam? (https://www.cfd-online.com/Forums/openfoam-solving/232435-how-control-transient-solution-max-iterations-per-time-step-openfoam.html)
alainislas December 14, 2020 04:14
Just as in fluent, one can control a transient simulation by limiting the number of iterations per time step (typically between 10 to 30 iterations/time step), independently if the convergence criteria is met or not.
I was wondering if something similar can be done in OpenFoam by modifying the fvSolution file or something. Any suggestion would be much appreciated,
Thanks you
CFD-HSNR December 14, 2020 05:48
Thanks you
Hello Alain,
You can set the minimum and maximum iteration steps via the keywords minIter and maxIter in the fvSolution.
alainislas December 17, 2020 10:42
Thank you very much! CFD-HSNR
