Simulation of a chimney with heat in open atmosphere |
December 7, 2020, 08:50 |
Jurado
Rep Power: 8 |
Good afternoon,
I am an phd student in machine learning and CFD. I am trying to model a chimney in an neutral open atmosphere with hot areas on top of the chimney. However, I cannot get my head around it and all my trial have unfortunately failed. I used the buoyantPimpleFoam from openFoam-6 from openFoam.org to try to simulate it. I think the issue reside in the boundary conditions, especially the ones for pressure and p_rgh. I initiate the pressure on the whole domain with a setField using the equation for isotherm atmosphere. To present more precisely my case, here are some images to present it in the attached files My simulation domain is a cube, with a face for : Inlet Two sides with symmetry A groud An outlet A roof that I have tried as an outlet and symmetry, both failing Because of the size of this simulation being too big, I have made a simplified case with a rectangular chimney that shows the same issues that I share in the attached files aswell as images of the geometry. there seem to be a problem at some point a vortex start to create itself behind the chimney and then the whole domain start to diverge Here is also my 0 files: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #include "include/initialConditions" dimensions [0 1 -1 0 0 0 0]; internalField uniform (1 0 0); boundaryField { // inlet air inletAir { type atmBoundaryLayerInletVelocity; #include "include/ABLConditionsInlet" } // symmetry symmetryRight { type symmetry; } symmetryLeft { type symmetry; } // solid surface wallGround { type uniformFixedValue; uniformValue (0 0 0); value uniform (0 0 0); } chimney { type uniformFixedValue; uniformValue (0 0 0); value uniform (0 0 0); } hot_area { type uniformFixedValue; uniformValue (0 0 2); value uniform (0 0 2); } // outlet symmetryRoof { type symmetry; //type freestreamVelocity; //freestreamValue uniform (3.15251 0 0); } outletPolAir { type freestreamVelocity; freestreamValue uniform (1 0 0); } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object T; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 1 0 0 0]; internalField uniform 293; boundaryField { // inlet air inletAir { type fixedValue; value uniform 293; } // symmetry symmetryRight { type symmetry; } symmetryLeft { type symmetry; } // solid surface wallGround { type fixedValue; value uniform 293; } chimney { type zeroGradient; } hot_area { type fixedValue; value uniform 343; } // outlet symmetryRoof { type symmetry; // type fixedValue; // value uniform 293; } outletPolAir { type zeroGradient; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 101325; boundaryField { // inlet air inletAir { type zeroGradient; } // symmetry symmetryRight { type symmetry; } symmetryLeft { type symmetry; } // solid surface wallGround { type zeroGradient; } chimney { type zeroGradient; } hot_area { type zeroGradient; } // outlet symmetryRoof { type symmetry; // type fixedValue; // value uniform 101203; } outletPolAir { type fixedFluxPressure; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 101325; boundaryField { // inlet air inletAir { type zeroGradient; } // symmetry symmetryRight { type symmetry; } symmetryLeft { type symmetry; } // solid surface wallGround { type zeroGradient; } hot_area { type zeroGradient; } chimney { type zeroGradient; } // outlet outletPolAir { type calculated; value 101325; } symmetryRoof { type symmetry; // type calculated; // value 95696.491; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object nut; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 0; boundaryField { #include "include/ABLConditionsDomain" // symmetry symmetryRight { type symmetry; } symmetryLeft { type symmetry; } symmetryRoof { type symmetry; } // solid surface wallGround { type nutkAtmRoughWallFunction; z0 $z0Ground; value uniform 0.0; } chimney { type nutkWallFunction; value uniform 0; } hot_area { type nutkWallFunction; value uniform 0; } // inlet and outlet ".*" { type calculated; value uniform 0; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object k; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #include "include/initialConditions" dimensions [0 2 -2 0 0 0 0]; internalField uniform $turbulentKE; boundaryField { // inlet air inletAir { type atmBoundaryLayerInletK; #include "include/ABLConditionsInlet" } // symmetry symmetryRight { type symmetry; } symmetryLeft { type symmetry; } symmetryRoof { type symmetry; } // solid surface wallGround { type kqRWallFunction; value uniform 0.0; } chimney { type kqRWallFunction; value $internalField; } hot_area { type kqRWallFunction; value $internalField; } // outlet ".*" { type inletOutlet; inletValue uniform $turbulentKE; value $internalField; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object epsilon; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -3 0 0 0 0]; #include "include/initialConditions" internalField uniform $turbulentEpsilon; boundaryField { // inlet air inletAir { type atmBoundaryLayerInletEpsilon; #include "include/ABLConditionsInlet" } // symmetry symmetryRight { type symmetry; } symmetryLeft { type symmetry; } symmetryRoof { type symmetry; } // solid surface wallGround { type epsilonWallFunction; Cmu 0.09; kappa 0.4; E 9.8; value $internalField; } chimney { type epsilonWallFunction; value $internalField; } hot_area { type epsilonWallFunction; value $internalField; } // outlet ".*" { type inletOutlet; inletValue uniform $turbulentEpsilon; value $internalField; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object alphat; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -1 0 0 0 0]; internalField uniform 0; boundaryField { // inlet air inletAir { type calculated; value uniform 0; } // symmetry symmetryRight { type symmetry; } symmetryLeft { type symmetry; } // solid surface wallGround { type compressible::alphatWallFunction; value uniform 0; } chimney { type compressible::alphatWallFunction; value uniform 0; } hot_area { type compressible::alphatWallFunction; value uniform 0; } // outlet symmetryRoof { type symmetry; // type calculated; // value uniform 0; } outletPolAir { type calculated; value uniform 0; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ flowVelocity (1 0 0); pressure 0; turbulentKE 1.3602E-01; turbulentEpsilon 9.3257E-04; // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Uref 3.15251; Zref 300; zDir (0 0 1); flowDir (1 0 0); z0 0.5; zGround 0; value $internalField; // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ z0Ground uniform 0.1; z0Block uniform 0.01; // ************************************************************************* // |
December 8, 2020, 05:05 |
Michael Alletto
Rep Power: 15 |
can you include an Allrun and Allclean script in your tar file? so it is easier for other people to know what you've done
December 8, 2020, 12:48 |
#3 | |
Jurado
Rep Power: 8 |
Hi mAlleto, Thank you for your replay. I added in this message the files with two allrun, one all run to make the mesh and the other allrun to run the computation on 10 cores. I also suppressed a file that were in constant and blocking computation. It runs on openfoam6. |
December 11, 2020, 06:08 |
Jurado
Rep Power: 8 |
I have tested a fixed inlet with a speed of 2.3 m/s and another of 1 m/s. Both end up failing with the 1m/s needing way more time to diverge (around 600s for the 1m/s vs 100s for the 2.3 m/s).
December 16, 2020, 07:49 |
#5 | |
Jurado
Rep Power: 8 |
I tried to increase the number of loop and to reduce the dt by lowering the CFL to 0.1 but still strange results. |
December 16, 2020, 11:50 |
Michael Alletto
Rep Power: 15 |
What OF version are you using. I tried to run it with OF2006 but it failed.
Why did you specify a free stream value of (1 0 0)? Code:
outletPolAir { type freestreamVelocity; freestreamValue uniform (1 0 0); } Code:
outletPolAir { type fixedFluxPressure; } What I see for the pressure boundary condition that you spesify all gradiends (fixedFluxPressure is kind of a specified gradient) did you try to specify a constant value at the outlet? |
December 17, 2020, 11:19 |
#7 | |
Jurado
Rep Power: 8 |
Hello mAlletto, Thank you for your reply. It is strange that it does not work for you, the version with the allrun works perfectly on my PC, probably an issue with openFoam version. The version I use is openfoam 6 from openfoam.org. I tried several condition for the output pressure like uniformHydrostaticPressure, calculated, totalPressure, freeStreamPressure but none worked. fixedFluxPressure seemed to be the one giving the "best result". |
December 18, 2020, 03:16 |
How does your case differ from the tutorial ./heatTransfer/buoyantBoussinesqPimpleFoam/hotRoom ?
Can you set up a 2D version allowing more comfortable test run in an initial stage of the project? Does simpleFoam run on your 2D case? |
December 18, 2020, 03:28 |
#9 |
Michael Alletto
Rep Power: 15 |
I saw you had a wall function for espilon at you inlet of the hot air. For k the same.
I suggest you to do the following: 1) Make a 2D flat plate case where you apply youre B.C at the inlet, outlet and symmetry to test if you setup works in this case. If not, than you have something fundamentally wrong. 2) Make a 2D flat plate case with a patch at bottom where you introduce the hot air 3) Make a 2D case with a chimney 4) Now you can go to 3D Increasing the complexity of your problem step by step helps you to understand the problem better and reduces the amount of errors you make. Furthermore you find errors more quickly. From my experience you get to your final result a lot faster since you avoid time consuming error search and waiting for the simulation to end. By the way, you do not need a transient solver. Your problem is steady and you can use a steady state solver. To test your setup use a very small mesh where the simulation runs through in a few seconds/minutes. This speeds up your search for the error a lot. It should run on one cpu not on 10... Best Michael |
December 18, 2020, 07:35 |
#10 | |
Jurado
Rep Power: 8 |
Thanks both for the reply My first trial was with this case boundary condition and it worked when the roof is not high. When the roof start reaching the hundred of meters the issue start appearing. My guess is that when the height is small the difference in pressure between the roof and ground is small. However when we start reaching high heights it is not longer the case and it makes the computation fail. I will set up a 2D version as mAlleto said to ease the trials. I will come back to post it once I am done. |
aerolics, chimney, neutral condition, open atmosphere, thermal |
Some questions about flow boiling simulation in Fluent | beastieboys6 | FLUENT | 8 | November 20, 2017 23:47 |
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X | gschaider | OpenFOAM Installation | 136 | October 10, 2017 17:25 |
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc | ofslcm | OpenFOAM Community Contributions | 25 | March 6, 2017 10:03 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
