September 18, 2020, 13:36 |
'sonicFoam' not found
Rep Power: 5 |
Good afternoon all,
I was trying to reproduce this tutorial: https://www.youtube.com/watch?v=Ds0e...nEnQqB&index=4 but I faced a fail with openFoam. I had issue only on solving part (not on mesh part). When I typed the sonicFoam command, the openFoam returned that sonicFoam was not found. """ Command 'sonicFoam' not found, but can be installed with: sudo apt install openfoam """ Them, Ubuntu suggested to install OpnFoam by sudo apt install openfoam. I tried that and it didn't solve my issue. I also searched on google for this issue and didn't find any solution. By the way, I am using: - Ubuntu18.04; - OpenFoam8 |
September 18, 2020, 17:57 |
Rep Power: 8 |
Since OpenFOAM 7 the functionality of sonicFoam is integrated into rhoPimpleFoam. You have to set "transonic true;" in the PIMPLE sub-dictionary in fvSolution to activate it. See: https://github.com/OpenFOAM/OpenFOAM...865321af6dd6ca
December 25, 2020, 21:10 |
R.M
Rep Power: 6 |
Many thanks Krapf for your help. Actually I had the same problem, but I have solved it by ur help.
December 26, 2020, 06:47 |
Two questions on the thermodynamics in sonicFoam and rho(S/P)impleFoam:
1/ Did sonicFoam allow to choose between rhoThermo and psiThermo? 2/ Any examples that show the benefit of rhoThermo and psiThermo given a certain application? Thx! |
#openfoam #sonicfoam |
Gmsh installation on terminal help | spitfire | Main CFD Forum | 4 | July 27, 2017 15:11 |
wmake error | zxj160 | OpenFOAM | 0 | March 26, 2012 10:52 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
OpenFOAM15 paraFoam bug | koen | OpenFOAM Bugs | 19 | June 30, 2009 10:46 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
