Adding temperature field to Channel Flow simulations
I am trying to add temperature field to channel flow simulations. So, firstly I have started with channel395 tutorial case. This test case is using cyclic boundary condition, which is not fine for temperature field, because I want to have at the inlet constant temperature. I found this solution: Quote:
I tried using mapping boundary condition, but here I get another problem, because I cannot get turbulent flow when using mapped boundary condition. Even if I start the simulation with mapped boundary condition, the turbulence dies down over time and I cannot see, where the problem is. I tried using mapped boundary condition before with different cases and it worked fine. Does anyone have any solutions to these two problems? Thanks! |
Hi!
So you have a cyclic flow field with a temperature field which is not cyclic? Can I ask you what kind of physical phenomena is this? |
Long story short, we are investigating temperature fluctuations at the heated wall experimentally, but also doing some simulations. Channel flow simulations are done as a sort of validation case. For calculating averages it is quite unpleasant to have cyclic boundary condition for temperature. But, I found the solution. The problem with my mapped inlet was, that the mapping was done for not long enough distance, so the turbulence couldn't develop. If anyone occurs the same problem - make the mapping length longer! |
