Removing cells
Old   January 20, 2021, 17:19
Default Removing cells
sasi
sasindra34@gmail.com is on a distinguished road
Respected Sir,
I am using coldEngineFoam to solve flow compression in cylinder using piston and it is 2D simulation. I want to remove cells during compression as cells size decrease much after compression. I tried different methods like dynamicRefineFvMesh but solver is not reading the file. Please give me your suggestions to solve this problem.
Thanks,
sasindra34@gmail.com is offline   Reply With Quote
dynamic mesh removal, remove cell
problem with parallel calculations OF8 mpirun otaolafr OpenFOAM Programming & Development 0 January 5, 2021 07:33
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 17:16
cellZone not taking all the cells inside rahulksoni OpenFOAM 0 January 16, 2019 01:16
[blockMesh] Removing interior cells shd01 OpenFOAM Meshing & Mesh Conversion 3 January 16, 2011 10:11
physical boundary error!! kris Siemens 2 August 3, 2005 00:32
