reactingMultiphaseEulerFoam + cyclicACMI compatibal?
Old   January 26, 2021, 04:36
Default reactingMultiphaseEulerFoam + cyclicACMI compatibal?
geth03 is on a distinguished road
Hi all,
OF Version 7,
solver: reactingMultiphaseEulerFoam
i am trying to run a simulation with the solver reactingMultiphaseEulerFoam. Before that i created 2 meshes, which i merged with mergeMeshes. for the interface i use cyclicalACMI, i already executed every necessary step successfully. i can run pimpleFoam, icoFoam & simpleFoam with no problem, but when i switch to reactingMultiphaseEulerFoam or reactingTwoPhaseEulerFoam, the solver does not even start.
i attached a screenshot.
my question is, is cyclicACMI compatibal with that solver?
or is cyclicalACMI specifically created for certain solvers?
cheers
Edit_1: i found a bug report on that issue: https://bugs.openfoam.org/view.php?id=3052
its not actually a bug, but i think cyclicACMI is not currently supported.
i also analyzed the solvers which can run that internal boundary, e.g. pimpleFoam and interFoam, and they support dynamic meshes.
Last edited by geth03; January 26, 2021 at 08:16. Reason: tested icoFoam, simpleFoam & reactingTwoPhaseEulerFoam, too.
geth03 is offline   Reply With Quote
Old   January 27, 2021, 05:14
so i finally fixed it somehow.
the problem was that initial boundary values were not well set for cyclicacmi patches.
Old   April 25, 2023, 09:34
Vinzenz Götz
Vinzmann is on a distinguished road
Hello Geth,
can you tell me how you fixed the issue?
Best regards,
Vinz
Vinzmann is offline   Reply With Quote
Old   April 25, 2023, 11:19
I cant remember exactly what i did to fix it to be honest, i am working with another mesh now, so i dont have that problem anymore.
Maybe you can describe your problem in detail (what you want to simulate, your mesh, solver, version, why does it now work, what is the error message) and i can try to help you.
Kind regards
Old   April 27, 2023, 02:34
Vinzenz Götz
Thanks for your reply.
I am trying to simulate a sixth of a vortex tube.
My mesh is made with snappyHexMesh. sHM crashes when the cyclicAMI patches are actually specified as cyclicAMI, so I mesh them as walls and afterwards use createPatch to change them to cyclicAMI. I used many more ways of achieving that. Even when not decomposed, the solver crashes.
I'm using reactingTwoPhaseEulerFoam on OF-v2212.
Error is always:
--> FOAM FATAL ERROR: (openfoam-2212)
Unable to set target face for source face 19081
    From virtual bool Foam::faceAreaWeightAMI::setNextFaces(Foam::label&, Foam::label&, Foam::label&, const Foam::bitSet&, Foam::labelList&, const Foam::DynamicList<int>&, bool) const
    in file AMIInterpolation/AMIInterpolation/faceAreaWeightAMI/faceAreaWeightAMI.C at line 361.
Best regards,
Vinz
rhoSimpleFoam MRF cyclicACMI centrifugal compressor dcook OpenFOAM Running, Solving & CFD 3 February 5, 2021 11:13
Flux across cyclicACMI coupled patches j.lisanti OpenFOAM Programming & Development 0 June 15, 2020 10:31
cyclicACMI + cyclic Yosmcer OpenFOAM Pre-Processing 18 February 12, 2019 21:12
Problem with periodically repeated partially overlapping patches / nested cyclicACMI Nysander OpenFOAM Running, Solving & CFD 1 October 10, 2017 11:01
cyclicAMI / cyclicACMI OF 2.3 Peter Müller OpenFOAM Running, Solving & CFD 0 February 21, 2014 10:36
