January 29, 2021, 12:13 |
How to set PhaseLimitStabilization?
Jason Dale
Rep Power: 17 |
I'm trying to use the PhaseLimitStabilization source in multiphaseEulerFoam to stop my alpha.water, alpha.oil and alpha.gas dropping too low and ultimately crashing the k-e model. I currently have this format in my fvOptions file: stabilize_epsilon.water { type symmTensorPhaseLimitStabilization; field epsilon.water; rate rLambda.water; residualAlpha 1e-3; } stabilize_epsilon.oil { type symmTensorPhaseLimitStabilization; field epsilon.oil; rate rLambda.oil; residualAlpha 1e-3; } stabilize_epsilon.gas { type symmTensorPhaseLimitStabilization; field epsilon.gas; rate rLambda.gas; residualAlpha 1e-3; } stabilize_k.water { type symmTensorPhaseLimitStabilization; field k.water; rate rLambda.water; residualAlpha 1e-3; } stabilize_k.oil { type symmTensorPhaseLimitStabilization; field k.oil; rate rLambda.oil; residualAlpha 1e-3; } stabilize_k.gas { type symmTensorPhaseLimitStabilization; field k.gas; rate rLambda.gas; residualAlpha 1e-3; } stabilize_U.water { type symmTensorPhaseLimitStabilization; field U.water; rate rLambda.water; residualAlpha 1e-3; } stabilize_U.oil { type symmTensorPhaseLimitStabilization; field U.oil; rate rLambda.oil; residualAlpha 1e-3; } stabilize_U.gas { type symmTensorPhaseLimitStabilization; field U.gas; rate rLambda.gas; residualAlpha 1e-3; } The solver seems to give the correct response Creating finite volume options from "constant/fvOptions" Selecting finite volume options model type symmTensorPhaseLimitStabilization Source: stabilize_epsilon.water Selecting finite volume options model type symmTensorPhaseLimitStabilization Source: stabilize_epsilon.oil Selecting finite volume options model type symmTensorPhaseLimitStabilization Source: stabilize_epsilon.gas Selecting finite volume options model type symmTensorPhaseLimitStabilization Source: stabilize_k.water Selecting finite volume options model type symmTensorPhaseLimitStabilization Source: stabilize_k.oil Selecting finite volume options model type symmTensorPhaseLimitStabilization Source: stabilize_k.gas Selecting finite volume options model type symmTensorPhaseLimitStabilization Source: stabilize_U.water Selecting finite volume options model type symmTensorPhaseLimitStabilization Source: stabilize_U.oil Selecting finite volume options model type symmTensorPhaseLimitStabilization Source: stabilize_U.gas My problem is still occurring, the alpha drives to very low values and crashes the k-e model, would anyone know if this is the correct way to do this? I've tested with and without and this doesn't seem to make a difference. Thanks Jason |
save to variable filename inside loop | FrankR | Fluent UDF and Scheme Programming | 5 | January 30, 2019 11:16 |
Ansys SIG$ILL error | loth | ANSYS | 3 | December 24, 2015 05:31 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
Install problem in linux | navaladi | OpenFOAM Installation | 11 | July 17, 2008 02:24 |
Ibm java gcc | rrr | OpenFOAM Installation | 2 | December 30, 2005 04:18 |
