OF div schemes greatly influence the result
Dear all:
I'm doing a simulation about wind aroud a flat roof. The model can be seen below. [image]https://www.cfd-china.com/assets/uploads/files/1611984747439-wholemodel.png[/img] In the reference paper, the author applied 'second order upwind' for space discretization in Fluent. And I have used the same model parameters (eg. domain size, minimum element size, boundary condition, turbulence model). simpleFOAM and realizable k-epsilon model are used. However I find that if I adopt different divergence schemes (namely, gauss upwind, linearUpwind and limitedLinear), the results will be different from each other and only the result of 'gauss upwind' agrees with that of reference paper. From what I gather, in openfoam 'gauss linearUpwind' represents 'second order upwind' which was adopted in the reference paper. But when I use 'gauss linearUpwind' for the divergence schemes in OpenFOAM, the simulated result (namely, friction velocity on roof) differs greatly from that of reference paper. In comparison, the performance improves if I adopted 'gauss upwind' which represented first order upwind. The results of different div schemes can be seen below. [image]https://www.cfd-china.com/assets/uploads/files/1611984885997-0f0345fa-d59b-4030-9578-0dcb60ab0d6f-image.png[/img] To describe my question detailedly, some details of my fvSchems and fvSolutions are also posted. Code:
ddtSchemes Code:
solvers That makes me confused. Could anyone please give me some suggestions? Thank you samuel |
You are using the wrong kind of schemes on bounded scalars - this will destabilize the solver.
If numerical diffusion is causing trouble, you can simply refine the mesh. Hrv |
Before that, I have found that my “k” boundary type seems to be unreasonable. Originally, I used kLowReWallFunction, after changing it to kqrWallFunction, the result becomes better. This also makes me confused. According to description, kLowREWallFunction is suitable for both low and high RE condition, while kqrWallFunction is only for high RE condtion. Is kLowREWallFunction unsuitable for realizable k-epsilon turbulence model? |
You may use Gauss upwind if you are looking for robust schemata. More accurate is linear upwind, but more oscillatory too.
