Help with 6dof large angular velocity, diverged results
Old   November 10, 2021, 20:48
Default Help with 6dof large angular velocity, diverged results
TWB
quarkz is on a distinguished road
Hi, I'm trying to simulate a wing with body tail doing a pitch up motion. Due to the lift of the wing in front of the CG, this will cause the whole wing body tail to pitch up.
Hence, the constraints are:
fixedPoint
                 sixDoFRigidBodyMotionConstraint point;
                 centreOfRotation (0. 0. 0.);
    fixedAxis
                sixDoFRigidBodyMotionConstraint axis;
                axis (0 0 1);
I managed to run for ~ 0.05s, after which the angular velocity gets bigger and bigger and eventually the solution diverged.
I tried a few things as recommended in the forum:
1. changing innerDistance/outerDistance from 0.3/1.0 to 0.5/5.0
2. accelerationRelaxation from 0.6 to 0.3
3. Trying Newmark, CrankNicolson, symplectic
I don't know what else I can do. Any other suggestions?
Thanks.
quarkz is offline   Reply With Quote
How to calculate swirl velocity or angular velocity in a in-cylinder flow analysis us tgsankar Main CFD Forum 2 April 26, 2017 16:55
Accessing parcel angular velocity from particel force class slint OpenFOAM Programming & Development 1 September 27, 2016 12:46
Turbine Angular Velocity Problem mechkween CFX 5 May 18, 2016 22:40
VELOCITY vs VELOCITY IN STN FRAME vs RELATIVE VELOCITY everest20 FLUENT 1 July 13, 2015 08:35
Obtaining angular velocity given linear velocity and center of rotation 3D quarkz Main CFD Forum 6 April 7, 2014 05:50
