[Sponsors] | |||||
Alan w
Rep Power: 7 ![]() |
Hi from a new member and a new Openfoam user. I am finally up and running, and succeeded in running a case with an airfoil fitted with a gurney flap. For guidance, I used the airfoil2D case in the tutorials. Attached is a screenshot of the flow tracer. My question is regarding the absence of the vortices that I expected to see. Is this because the simpleFoam solver is not sophisticated enough for vortical flow? How do I proceed to capture this more advanced flow?SnapCrab_NoName_2021-2-12_15-24-55_No-00.png
Rep Power: 17 ![]() |
simpleFoam should be able to capture a steady state solution of the vortices in the wake. In my experience, you would need to move the line that enables showing of streamlines just behind the back of your geometry.
Alan w
Thanks Bazinga,
I tried moving the seed line for the streamlines as you suggested, but there are still no vortices. I have carefully compared all of my setup files to the tutorial, but haven't found any differences. Help! I really need to get to the bottom of this! boffin5 |
Rep Power: 8 ![]() |
Your velocity range is quite low. Did you manually adjust the range? Or are your velocities that low? 0.1 m/s?
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Vortex method - limited no of vortices | heisenmech | FLUENT | 1 | March 23, 2019 16:21 |
| I am confused as to how quasi-streamwise vortices are formed in a channel. | David81 | Main CFD Forum | 1 | May 29, 2017 07:58 |
| Hairpin vortices in turbulent channel flow using DNS | Nitin Minocha | Main CFD Forum | 2 | November 21, 2016 18:52 |
| Initializing trailing vortices in fluent | zakir | FLUENT | 1 | February 16, 2014 08:54 |
| von Karman vortex street. Vortices formation mechanism. | mnvl | Main CFD Forum | 1 | February 24, 2010 18:53 |
