OpenFOAM Parallel Runs Problems on Dual-CPU Computer |
Febriyan Prayoga
Rep Power: 11 ![]() |
Dear Foamer.
I am running OpenFOAM-v2012 on dual-CPU Computer (2x Xeon E5 @14 cores=28 thread, so total 56 threads on the Computer). I am researching with rhoCentralFoam to run 2D axisymmetric case. The domain decomposition works well after I run "decomposePar". But the problem arose when i tried to run the case in parallel with all threads. I used this command to run it on script named ./gas0 , "mpirun -H localhost --oversubscribe -np 56 rhoCentralFoam -parallel > log.run1" then I run "tail -f log.run1". but the terminal looks freeze as shown in picture 1. Then i run "top" on other terminal and there were 56 process running rhoCentralFoam. I check the System Monitor also the CPUs were full occupied. Here are the additional information: 1. I have tried install openfoam from precompiled and built from source but the same problems arose. 2. The computer is dual boot between windows10 and ubuntu 20.04. 3. gcc version 9.3.0, g++ version 9.3.0, mpiexec --version 4.0.3 4. the simulation runs propely on SERIAL. 5. the simulation works properly when the processor assigned not exceeding 14. "-np 14". 6. I could upload the case if necessary. I am really newbie running and installing OpenFOAM on dual-nodes processors/server PC/small cluster. Previously I run OpenFoam on single node CPU, this type of problem never arise. I have searched some references in this forum but couldnot find the solution. I will be very thankful if someone could guide me to find the solution to overcome this problem to runs openfoam parallel all cores on dual-nodes PC. Any guidance to reference or forums threads are very welcome x) ![]() Regards, Febriyan |
Ignacio
Rep Power: 0 ![]() |
Hello Foamers,
Bringing this up with a similar question of my own I have been running OpenFOAM (v2112 now) for some time on a 8 core processor without issues when working in parallel. I have now access to a 2x CPU machine with 2 x Intel® Xeon® Gold 6240 18c. I wanted to give it a try to further decompose my domain and check how it compares with my previous setup. I have the same problem as the OP. I have been able to decompose up to 18c but I cannot get it to go any further without triggering the error that is discussed above. I have similar specs (mpiexec --version 4.0.3...) I think mpi only "sees" one processor and that I should probably specify that I have in fact 2 CPUs. After some investigation I have tried running: Code:
mpirun --host node1:16,node2:16 -np 32 snappyhexmesh -parallel Code:
ssh: Could not resolve hostname node2: Temporary failure in name resolution -------------------------------------------------------------------------- ORTE was unable to reliably start one or more daemons. This usually is caused by:... Code:
ORTE does not know how to route a message to the specified daemon located on the indicated node: |
#3 | |
Huan Zhang
Rep Power: 6 ![]() |
Have you found the solution? I have the same problem. I have a dual-cpu with 24*2 cores, but it seems that I can only use one cpu when I use the general script mpirun -np 38 interFoam -parallel. It will give me errors when I use cores larger than 24. How to make parallel runs on 2 cpus? Any suggestions? Thank you, Jasper |
fardin
Rep Power: 8 ![]() |
Dear all,
febriyan91, he made the correct code and for sure his case at that time was running. What he had do was just delete "> log.run1" because this command says to just write output to a file named "log.run1". So, literally there wont be anything printed in the terminal. But If you want to use all cores of a multi-CPU PC you need to run your solver using following command: "mpirun -H localhost --oversubscribe -np 56 rhoCentralFoam -parallel" where 56 is your number of cores. |
Display Modes | |
[OpenFOAM.com] problems running in parallel on Mac OS X and Windows: only 1 cpu | windscion | OpenFOAM Installation | 20 | June 5, 2020 16:27 |
Openfoam parallel calculation performance study - Half performance on mpirun | Jurado | OpenFOAM Running, Solving & CFD | 22 | March 24, 2018 20:40 |
Two computer cluster - problems with settings | dradenkovic | OpenFOAM Running, Solving & CFD | 9 | November 13, 2017 04:16 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
Can not run OpenFOAM in parallel in clusters, help! | ripperjack | OpenFOAM Running, Solving & CFD | 5 | May 6, 2014 15:25 |
