February 23, 2018, 04:28 |
3 phase multiphaseInterFoam
Rep Power: 9 |
I am trying to simulate flow around a (boat like) object in stratified waters. Fluids: air, fresh water and salt water. Dimensionality: 2D. Solver: multiphaseInterFoam. The result does not look good: For U I get some kind of wake infront of the object: uAirSaltFresh.jpg The phases look like alphaAirFreshSalt.jpg The above is not what I expected. I have run two other scenarios. The 2nd scenario is two phases with air and salt water. For U I then get uAirSalt.jpg For alphas I get alphasAirSalt.jpg Comparing the two above scenarios, we see that the last scenario get a more reasonable velocity profile infront of the object. Finally, I have run a 2-phase case between fresh water and salt water. For alpha I then get alphaSaltFresh.jpg Comparing the last picture with the corresponding 3-phase picture, we see that there is a big difference in alpha distribution. In the last case we get a nice internal wave. I cannot figure out why the 3-phase simulations give such bad results. It seems like openFoam and multiphaseInterFoam (which is used in all scenarios) can handle different combinations of two fluids well, but everything blows up when combing all fluids together in the 3-phase simulation. In the next post I will add the BC-files for the 3-phase simulation. |
February 23, 2018, 04:42 |
Rep Power: 9 |
Continuation from previous post:
Some files: alpha.air Code:
dimensions [0 0 0 0 0 0 0]; internalField uniform 0;//1; boundaryField { //- Set patchGroups for constraint patches #includeEtc "caseDicts/setConstraintTypes" inlet { type fixedValue; value $internalField;//uniform 1;// } outlet { //type zeroGradient; type variableHeightFlowRate; lowerBound 0; upperBound 1; value $internalField; } atmosphere { type inletOutlet; inletValue uniform 1;//$internalField; value uniform 1;//$internalField; } barge { type zeroGradient; } } Code:
dimensions [0 0 0 0 0 0 0]; internalField uniform 1; boundaryField { //- Set patchGroups for constraint patches #includeEtc "caseDicts/setConstraintTypes" inlet { type fixedValue; value $internalField;//uniform 0;// } outlet { type variableHeightFlowRate; lowerBound 0; upperBound 1; value $internalField;//uniform 1; } atmosphere { type inletOutlet; inletValue uniform 0;//$internalField; value uniform 0;//$internalField; } barge { type zeroGradient; } } Code:
dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { //- Set patchGroups for constraint patches #includeEtc "caseDicts/setConstraintTypes" inlet { type fixedValue; value $internalField; } outlet { type variableHeightFlowRate; lowerBound 0; upperBound 1; value $internalField; } atmosphere { type inletOutlet; inletValue $internalField;//uniform 0; value $internalField;//uniform 0; } barge { type zeroGradient; } } Code:
Umean 0.24; mUmean -0.24; dimensions [0 1 -1 0 0 0 0]; internalField uniform ($mUmean 0 0); boundaryField { //- Set patchGroups for constraint patches #includeEtc "caseDicts/setConstraintTypes" inlet { type fixedValue; value $internalField; } outlet { type outletPhaseMeanVelocity; alpha alpha.saltWater; Umean $Umean; value $internalField; } atmosphere { type pressureInletOutletVelocity; tangentialVelocity $internalField; value $internalField;//uniform (0 0 0); } barge { type movingWallVelocity; value uniform (0 0 0); } } Code:
dimensions [1 -1 -2 0 0 0 0]; internalField uniform 0; boundaryField { //- Set patchGroups for constraint patches #includeEtc "caseDicts/setConstraintTypes" inlet { type fixedFluxPressure; value $internalField; } outlet { type zeroGradient; //type fixedFluxPressure; //value $internalField; } atmosphere { type totalPressure; p0 uniform 0; } barge { type fixedFluxPressure; value $internalField; } } Code:
solvers { /*"alpha.*" { nAlphaSubCycles 4; cAlpha 1; }*/ "alpha.*" { nAlphaCorr 1; nAlphaSubCycles 2; cAlpha 1; icAlpha 0; //from dtcHull MULESCorr yes; nLimiterIter 10; alphaApplyPrevCorr yes; solver smoothSolver; smoother symGaussSeidel; tolerance 1e-8; relTol 0; minIter 1; } /* "pcorr.*" { solver PCG; preconditioner { preconditioner GAMG; tolerance 1e-05; relTol 0; smoother GaussSeidel; } tolerance 1e-05; relTol 0; maxIter 100; } p_rgh { solver GAMG; tolerance 1e-07; relTol 0.05; smoother GaussSeidel; } p_rghFinal { solver PCG; preconditioner { preconditioner GAMG; tolerance 1e-07; relTol 0; nVcycles 2; smoother GaussSeidel; } tolerance 1e-07; relTol 0; maxIter 20; } */ "pcorr.*" { solver PCG; //preconditioner DIC; preconditioner { preconditioner GAMG; smoother GaussSeidel; tolerance 1e-5; relTol 0; }; tolerance 1e-5; relTol 0; } p_rgh { //solver PCG; solver GAMG; smoother DIC; //preconditioner DIC; tolerance 1e-07; //relTol 0.05; relTol 0.01; //absTol 0; } p_rghFinal { $p_rgh; relTol 0; } /* "(U|k|omega).*" { solver smoothSolver; smoother GaussSeidel; tolerance 1e-08; relTol 0.1; nSweeps 1; } */ "(U|k|omega).*" { solver smoothSolver; smoother symGaussSeidel; nSweeps 1; tolerance 1e-06; relTol 0.1; minIter 1; } /* UFinal { $U; tolerance 1e-08; relTol 0; } */ } /* PIMPLE { nCorrectors 2; nNonOrthogonalCorrectors 0; } */ PIMPLE { momentumPredictor no;//yes; nOuterCorrectors 1; nCorrectors 3; nNonOrthogonalCorrectors 0; } /* relaxationFactors { equations { "U.*" 1; } } */ relaxationFactors { equations { //p_rgh 0.5; //U 0.5; ".*" 1; } } cache { grad(U); } Code:
ddtSchemes { default Euler;//localEuler; } gradSchemes { default Gauss linear; limitedGrad cellLimited Gauss linear 1; } divSchemes { div(rhoPhi,U) Gauss linearUpwind grad(U); div(phi,alpha) Gauss vanLeer; div(phirb,alpha) Gauss linear; div(phi,k) Gauss upwind; div(phi,omega) Gauss upwind; //div(phi,k) Gauss linearUpwind limitedGrad; //div(phi,epsilon) Gauss linearUpwind limitedGrad; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; //laplacian(diffusivity,cellMotionU) Gauss linear uncorrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } wallDist { method meshWave; } Code:
defaultFieldValues ( volScalarFieldValue alpha.air 0 volScalarFieldValue alpha.freshWater 1 volScalarFieldValue alpha.saltWater 0 ); regions ( boxToCell { box (-120 0 0) (20 40 200); fieldValues ( volScalarFieldValue alpha.freshWater 0 volScalarFieldValue alpha.saltWater 0 volScalarFieldValue alpha.air 1 ); } boxToCell { box (-120 0 -100) (20 40 -0.2); fieldValues ( volScalarFieldValue alpha.freshWater 0 volScalarFieldValue alpha.saltWater 1 volScalarFieldValue alpha.air 0 ); } boxToFace { box (-120 0 0) (20 40 200); fieldValues ( volScalarFieldValue alpha.freshWater 0 volScalarFieldValue alpha.saltWater 0 volScalarFieldValue alpha.air 1 ); } boxToFace { box (-120 0 -100) (20 40 -0.2); fieldValues ( volScalarFieldValue alpha.freshWater 0 volScalarFieldValue alpha.saltWater 1 volScalarFieldValue alpha.air 0 ); } ); - Refining mesh - Increase nAlphaSubsycles - Increase alphaCorr - Decrease deltaT - Change maxCo and maxAlphaCo - Change the phase used in the outlet BC for U (Results become even worse if alpha.fresh water is used here) - Increase size of mesh As a side note, the two-phase solutions, which I have simulated with multiphaseInterFoam, is also simulated with interFOam, giving similar results. Any help will be very appreciated! |
March 1, 2018, 03:14 |
Paul Palladium
Rep Power: 10 |
I would model the salt water using a passive transport scalar and not a dedicated phase. When you use interfoam solver you assume that phases are non miscible. This not the case between salt water and fresh water.
For example if you want to model the dispersion of smoke in air from a chimney output you will use a passive scalar to track the smoke concentration. Fauster |
March 23, 2018, 01:20 |
#4 | |
Rep Power: 9 |
Is this what twoLiquidMixingFoam does? |
March 6, 2021, 12:33 |
Reviewer #2
Rep Power: 10 |
alphaEqn.H in twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM Bugs | 15 | May 1, 2016 16:12 |
[swak4Foam] mass conservation of solid phase violated when using groovyBC with twoPhaseEulerFoam | xpqiu | OpenFOAM Community Contributions | 8 | June 17, 2015 02:08 |
iteration questions in discrete phase | iknowjesus | FLUENT | 4 | March 13, 2015 06:07 |
Phase segregation in multiphaseInterFoam | Tracker | OpenFOAM | 3 | May 7, 2010 04:10 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
