dynamicMotionSolverFvMesh on one cellZone only
Old   September 27, 2012, 07:11
Default dynamicMotionSolverFvMesh on one cellZone only
Stefan Sicklinger
clean-energy is on a distinguished road
I would like to combine AMI and the dynamicMotionSolverFvMesh (displacementLaplacian) for FSI with rotating meshes.
Is it possible to limit somehow the cellZone on which the displacementLaplacian is solving the mesh motion equation?
Thanks for your comments in advance!
clean-energy is offline   Reply With Quote
Old   October 30, 2012, 15:33
Kanuk
kanuk is on a distinguished road
I'm also interested in this topic.
Anyone out there have any success (or failures) with ami (or ggi) for FSI with rotating meshes?
kanuk is offline   Reply With Quote
Old   October 31, 2012, 02:58
Hrvoje Jasak
We have done a wind turbine with FSI for a blade: you will have to write your own dynamic mesh class for this.
Hrv
Hrvoje Jasak
Old   June 2, 2020, 09:13
Default Similar issue
Conor
ConorMD is on a distinguished road
Hi Guys,
In the 8 years since this thread was started, has the ability to apply the displacementLaplacian on one cellZone only been implemented?
I am trying to model a VAWT blade and its deflections using Calculix.
When combining solidBody motion with displacementLaplacian I get an error where the rotating body shrinks to a point where the simulation fails (see attached image).
Is there any way around this?
Thanks,
Conor
ConorMD is offline   Reply With Quote
Old   February 28, 2021, 18:49
cyss38's Avatar
Cyrille Bonamy
cyss38 is on a distinguished road
Originally Posted by ConorMD View Post
Hi Guys,
Thanks,
Conor
Hi Conor,
I have similar issue, with similar problem (oscillating blade and its deflections using Calculix via precice).
Did you solve the problem?
cyss38 is offline   Reply With Quote
pointZone to cellZone Peter_600 OpenFOAM 5 July 17, 2012 03:33
[mesh manipulation] Selecting cellzone using cellSet in OpenFOAM-1.7.0 ggoggodak85 OpenFOAM Meshing & Mesh Conversion 0 April 25, 2012 05:48
porous media (cellzone) thisisit FLUENT 1 November 24, 2011 03:32
How to compute cellZone volume vinz OpenFOAM Programming & Development 11 August 2, 2010 17:38
[snappyHexMesh] How can I put snappy layers in a separate cellzone? overkligheten OpenFOAM Meshing & Mesh Conversion 1 April 5, 2010 09:18
