Time step continuity error (cumulative very high ~ 0.89) |
February 12, 2021, 10:34 |
chandra shekhar pant
Rep Power: 16 |
Hello Foamers,
I am trying to run a simpleFOAM solver for a 2D aerofoil, I have a strange output regarding the Time step continuity error, which says: Code:
time step continuity errors : sum local = 1.57644e-08, global = -5.51118e-10, cumulative = 0.895961 |
February 13, 2021, 10:50 |
Rep Power: 14 |
Well, the cumulative error is the running total of the global error from each time step:
https://www.openfoam.com/documentati...uityError.html so at some point in your earlier time steps you must have some iterations where the global continuity error was large. Perhaps seek this out and find out why? Otherwise, since this is steady state and the "problems" are in the past - perhaps you shouldn't care? If the solution is well converged now (we can't tell this from the single log file line that youposted), then everything is fine and it doesn't matter that you had a rocky road to get there (albeit future simulations might be smoother/easier if you figure out what the problem was). |
March 2, 2021, 07:02 |
Rep Power: 16 |
Many thanks Tobermory for your help and elaborated explanation. I highly appreciate that.
Transient simulation not converging | skabilan | OpenFOAM Running, Solving & CFD | 14 | December 16, 2019 23:12 |
Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 10:08 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
AMI interDyMFoam for mixer nu problem | danny123 | OpenFOAM Programming & Development | 8 | September 6, 2013 02:34 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
