Flat plate (H-type) transition using Dynamic Smagorinsky Model
Old   March 4, 2021, 02:03
Default Flat plate (H-type) transition using Dynamic Smagorinsky Model
Anonymous
backscatter is on a distinguished road
Hi all,
Has anyone done LES of H-type flat plate transition cases using Dyn. Smagorinsky model?
Thanks,
backscatter is offline   Reply With Quote
Old   April 20, 2021, 09:03
mooy
snowboy is on a distinguished road
Hi ,
Have you solved this problem? I know that there should be a disturbance strip applied upstream of separation triggers the transition of shear layer, but i have no idea how to set it. Can you give me some advice?
Thanks,
snowboy is offline   Reply With Quote
Old   April 21, 2021, 17:41
Anonymous
Originally Posted by snowboy View Post
Hi ,
Thanks,
You can use groovyBC to set up the transpiration velocity at the disturbance strip.
Drag Force Ratio for Flat Plate Rob Wilk Main CFD Forum 40 May 10, 2020 05:47
natural convection in square cavity having inlet and outlet sujeet OpenFOAM Running, Solving & CFD 1 November 2, 2019 03:17
rhoPimpleFoam hardship petrus OpenFOAM Running, Solving & CFD 0 October 7, 2016 03:41
boundary conditions for simpleFoam calculation foam_noob OpenFOAM Running, Solving & CFD 8 July 1, 2015 09:07
T Junction Stability ignacio OpenFOAM Running, Solving & CFD 5 May 2, 2013 11:44
