Memory usage of pimpleFoam in parallel
I am running LES using pimpleFoam on 20 physical cores. Mesh size is around 7 millions. In the Task Manager window, I see 20 "pimpleFoam -parallel" processes, each using 2.4GiB of memory. Does that mean the total memory usage is 2.4 * 20 = 48GB? This looked too much for such a run, but also 2.4GiB total memory usage sounds too small. https://i.ibb.co/DRK3xsW/Screenshot-...0-19-05-04.png 65 png So which one should I consider? Best regards, Huseyin Specs: 24-core AMD Threadripper 3960x CPU 64GiB of memory OS: Xubuntu 20.04 |
The task manager is reporting all the processes. When you decompose to run on 20 processors, you spawn 20 processes ... so each line you see in the task manager is a separate process, each of 2.4GB ... so yes, it is using 48GB in total.
The other way to check total memory usage is to open a terminal and type Code:
free -h |
